2005 Excusion and 2011 F-250 Take Offs - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 08-14-2010, 08:42 PM
Ben FORD's Avatar
Ben FORD Ben FORD is offline
Ben FORD is starting off with a positive reputation.
Hi,
I have a 2005 Excursion diesel. I have the opportunity to get some take off tires and wheels from a 2011 F-250 SD Lariat. Are the bolt patterns the same? Any issues I need to be aware of? Thanks!!!!
Old 08-14-2010, 08:55 PM
Hybris's Avatar
Hybris Hybris is offline
Hybris is gaining momentum as a positive member of FTE.Hybris is gaining momentum as a positive member of FTE.
More then likely you will need wheel spacers to match the bolt pattern and for proper backspacing.
I'm sure some will recommend a place to get a wheel spacer but the advice I can give is make sure you get hub centric spacers and make sure they are heavy duty steel spacers.
Old 08-15-2010, 10:10 AM
Ben FORD's Avatar
Thanks for the rsponse. I'm not familiar with wheel spacers so I will have to look into that. I was hoping the 2011 wheels would be just an easy swap.
Old 08-15-2010, 01:00 PM
TYZ78F150 TYZ78F150 is offline
TYZ78F150 is gaining momentum as a positive member of FTE.
Quote:
I think anything from 2005 and up needs a spacer as the b/s is different. I believe 99-04 would fit 05 and up, just not the other way around w/out spacers. Just do us and you and your family a favor and get good(expensive) spacers. Well worth the $$$. Show it off once you get them.
Old 08-15-2010, 06:17 PM
71-4R3SONS's Avatar
71-4R3SONS 71-4R3SONS is offline
71-4R3SONS has a good reputation on FTE.71-4R3SONS has a good reputation on FTE.
Do a "search" here in the X forum and you'll find lots of info... You'll need 2 inch hubcentric spacers... get them here: wheelspacers.com
Search my posts....high1 posts and MONSTA posts... there are others with 05 up SD OEM wheels on Excursions... We were some of the first to do the swap.
Happy reading!
MY MODS
Old 08-16-2010, 04:56 PM
fielddominance fielddominance is offline
fielddominance is starting off with a positive reputation.
Bob,
Do you still have the F250 20" OEMs on your truck??? If so, do you absolutely love them??? And if not, why???
I had MotoMetals 20" w/ Nittos and ended up hating it!!! went back to Factory 16" uglys. But I am itching for the 20" f250s... just dont want to make the same mistake.
Thanks,
P
Happy reading!
MY MODS
Old 08-16-2010, 05:49 PM
Monsta's Avatar
Monsta Monsta is offline
Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.
Quote:
Originally Posted by Hybris View Post
.... but the advice I can give is make sure you get hub centric spacers and make sure they are heavy duty steel spacers.
The spacers from wheeladapters.com are aluminum. You don't need steel.
You also eliminate galvanic corrosion by using aluminum since the wheels are aluminum. Ask anyone who's ever tried to get the aluminum wheels of the stock mating surface in the dark, at night, in the rain, with a car full of people just to change a flat: Galvanic corrosion sucks.
Which reminds me. Your spare will become absolutely useless so plan to either get a matching 5th rim or something that can repair a flat enough to get you home/repair shop.
Old 08-16-2010, 09:42 PM
71-4R3SONS's Avatar
Quote:
Originally Posted by fielddominance View Post
Bob,
Of course I still have them on... it's the summer!! I run my OEM 20's from April to November... And run the stock 16 inchers from November to April.
We have nasty winters here in the northeast!!
Yep!!! I love them !!!
MY MODS
Old 08-20-2010, 08:19 PM
Ben FORD's Avatar
OK - so which are the best spacers / adapters to use for the money and safety of the family? Thanks
Old 08-20-2010, 08:52 PM
71-4R3SONS's Avatar
wheelspacers.com
Old 08-21-2010, 10:08 AM
Ben FORD's Avatar
I talked with Fred Geske from wheeladapters.com last night, heck of a nice guy but the $640.00 is bugging me. I know safety is the most important thing but are these that are on ebay unsafe? Has anyone used them? The $280.00 seems more realistic.
4 2005 Ford Excursion 05 Wheel Spacers Adapters 8x170 2: eBay Motors (item 280471268019 end time Aug-26-10 04:30:55 PDT)
Old 08-21-2010, 10:20 AM
71-4R3SONS's Avatar
Yes, the spacers pictured above are VERY unsafe. They are not hubcentric. You can see in the pic below (thanks high1) the small "lip" at the inner hub circle. That is what makes it hubcentric as opposed to lugcentric the ones pictured above.
You can not put a price on safety... that is one reason why I drive the biggest SUV ever built.
Buy from Fred.
MY MODS
Old 08-21-2010, 10:23 AM
Ben FORD's Avatar
Thanks for the education. I see the difference now. I will get them from Fred.
Safety is why we bought the Excursion too!!!
Old 08-21-2010, 04:53 PM
Snowseeker's Avatar
Snowseeker Snowseeker is offline
Snowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputation
Are those wheel spacers steel or aluminum? Wheel spacers are a scary thing and personly I wouldn't use them. I have seen a few times where lugs have been sheared off with wheel spacers (probably incorrect spacers).
Towing especially I wouldn't use them but that is a personal thing.
Old 08-21-2010, 07:24 PM
Monsta's Avatar
They're aluminum and nothing to be scared of. I've seen one Excursion where one sheared off due to the owner not grinding down the stock studs. That made the spacers not seat fully. Most issues with spacers are operator error.
Listen, all F350 duallys use spacers up front.
2008-2011 Factory Tow mirrors on a 2005??? SaleenS281 1999 to 2016 Super Duty 9 01-03-2017 02:15 PM
Will a 2010 or 2011 F250 bed fit on a 2005 F250? 1sicksrt8 1999 to 2016 Super Duty 15 01-08-2016 01:20 PM
light problems pls help terby348 Electrical Systems/Wiring 1 02-01-2015 08:29 AM
power folding tow mirror mck2000 1999 to 2016 Super Duty 1 09-01-2013 11:46 AM
2011 Rear Bumper on 2005 cbzdel 1999 to 2016 Super Duty 1 02-27-2012 02:42 PM
Tags
07, 2011, bolt, edition, excursion, f250, fit, ford, high1, oem, pattern, special, takeoffs, trucks, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
