2005 Excusion and 2011 F-250 Take Offs - Page 2 - Ford Truck Enthusiasts Forums
Old 08-22-2010, 08:52 AM
Snowseeker's Avatar
Snowseeker Snowseeker is online now
Snowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputation
Quote:
Originally Posted by Monsta View Post
Listen, all F350 duallys use spacers up front.
Yes OEM steel ones.
Old 08-23-2010, 07:00 PM
Ben FORD's Avatar
Ben FORD Ben FORD is offline
Ben FORD is starting off with a positive reputation.
I ordered a steel set from Fred at wheeladapters.com. I will post some pics when I'm all set-up. Thanks
Old 03-13-2011, 04:11 PM
sean23johnson's Avatar
sean23johnson sean23johnson is offline
sean23johnson is starting off with a positive reputation.
Quote:
Bringing back from the dead. Any pics??? I am interested in newer SD wheels on my 99.
Old 03-13-2011, 06:10 PM
Ben FORD's Avatar
We got the adapters from Fred, added a new springs on the front for a 2" lift and added air bag on the rear. We had to grind about 1/4" off the front studs.
Old 03-13-2011, 06:17 PM
Wow that looks really good!!! Do the tires stick put past the fenders? Did you get 2" or 2.5" spacers? Also what size tires are you running? Sorry for all the questions, just gathering info.
Old 03-13-2011, 06:23 PM
Ben FORD's Avatar
Thanks - we got the 2" spacers. With 2" spacers the tires do not stick out any further than the stock tires/wheels. The tires are stock tires for a 20" rim 2011 F-250.
Old 03-14-2011, 08:43 AM
MoreBoostPlease's Avatar
MoreBoostPlease MoreBoostPlease is offline
MoreBoostPlease is gaining momentum as a positive member of FTE.
Your Ex looks perfect! What size are the tires? Also, what lift did you go with?
Old 03-15-2011, 12:43 AM
bigrayq's Avatar
bigrayq bigrayq is offline
bigrayq is starting off with a positive reputation.
Harley f-250 20's with no lift, wheel adapters from Fred at Wheeladapters.com
Old 07-09-2011, 09:07 AM
Fordfanatic69 Fordfanatic69 is offline
Fordfanatic69 is starting off with a positive reputation.
Is everybody having to grind down the factory studs
Old 02-11-2012, 11:22 AM
Ben FORD's Avatar
I had to grind down the front wheel studs about 1/8th - 1/4th inch. Update - Just checked the spacer torque for the second time since putting these adapters on and no torque was lost. We also ended up having new blocks made for the back so that there wasn't so much air in the air bags. The ride is much better with so swaying.
Old 04-29-2013, 07:39 PM
High Intentions's Avatar
High Intentions High Intentions is offline
Mod Specialist ;)
High Intentions has a superb reputationHigh Intentions has a superb reputationHigh Intentions has a superb reputationHigh Intentions has a superb reputationHigh Intentions has a superb reputationHigh Intentions has a superb reputationHigh Intentions has a superb reputationHigh Intentions has a superb reputationHigh Intentions has a superb reputationHigh Intentions has a superb reputationHigh Intentions has a superb reputation
You just have to grind down the fronts only and not the rear studs?
Old 10-06-2013, 06:45 PM
xplodn xplodn is offline
xplodn is starting off with a positive reputation.
Bringing it back from the dead. I picked up a 2005+ OEM 18's today for a steal. It seems that the Coming Soon page website is down where has anyone found good spacers lately?
Here is a set of hub Centric ones-
Ford 8x170 2.00" Wheel Spacers : Amazon.com : Automotive Ford 8x170 2.00" Wheel Spacers : Amazon.com : Automotive
  #28
Old 10-07-2013, 01:51 PM
DavenTn's Avatar
DavenTn DavenTn is offline
DavenTn has a very good reputation on FTE.DavenTn has a very good reputation on FTE.DavenTn has a very good reputation on FTE.DavenTn has a very good reputation on FTE.
Quote:
Here is a set of hub Centric ones- Ford 8x170 2.00" Wheel Spacers : Amazon.com : Automotive
They look fine to me. They're aluminum and I noticed the price is for 2 ... so 4 = 480.00. If it were me, it's important to know they're made/machined from billet 6160 T-6 and I did not see that in the description. I agree... Aluminum adds less unsprung weight to the suspension but steel is more forgiving. However I see no reason why these spacers would be just fine and dandy though.
I will say without reservation, there are lots of horror stories with Aluminum spacers. FYI... anytime aluminum and dissimilar metals are combined/bolted together, use a inhibiting compound. I like NO-OX special ID and it has tons of other uses as well.
  #29
Old 10-07-2013, 02:29 PM
Apocalypse's Avatar
Apocalypse Apocalypse is offline
Apocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputation
I used the "cheap" ebay spacers that ARE hubcentric and they are perfect. Personally I think it's a waste to buy the exact same thing for more money but others disagree. My 2 cents.
  #30
Old 10-07-2013, 04:21 PM
ycis ycis is offline
ycis has a good reputation on FTE.ycis has a good reputation on FTE.
that black ex looks sick! love it
I think someone did the math in another thread about hub vs lug centric....and that you had very little to worry about in "shearing off" 8 individual grade 8 bolts....no matter how much you tow.
2008-2011 Factory Tow mirrors on a 2005??? SaleenS281 1999 to 2016 Super Duty 9 01-03-2017 01:15 PM
Will a new F250 Steering Wheel fit a 2005 EX? PI360 Excursion - King of SUVs 16 04-11-2016 07:13 PM
Will a 2010 or 2011 F250 bed fit on a 2005 F250? 1sicksrt8 1999 to 2016 Super Duty 15 01-08-2016 12:20 PM
light problems pls help terby348 Electrical Systems/Wiring 1 02-01-2015 07:29 AM
power folding tow mirror mck2000 1999 to 2016 Super Duty 1 09-01-2013 10:46 AM
Tags
07, 2011, bolt, edition, excursion, f250, fit, ford, high1, oem, pattern, special, takeoffs, trucks, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
