how to remove rust on frame
Old 08-14-2010, 05:16 PM
hatchet's Avatar
hatchet
hatchet is offline
my 94 f 250 4x4 has alot of rust on the frame i havent really owned the truck that long maybe 4 monts or so but the guy I bought it from plowed snow with it and looks like he never washed it much after he plowed.the rust on the frame i tryed sanding it off with a cup wire brush on a drill and it wont come off.The rust is as hard as a rock for some reason.how do i get this rust off before the truck falls apart?would a sandblaster take it off?i was thinking of buying a cheap sandblaster if it will remove the rust.but not really sure where to buy one.
Old 08-14-2010, 05:46 PM
leavy20's Avatar
leavy20
leavy20 is offline
i am in the process of cleaning up my 150 and will say i am going to be using a knotted wire wheel on an angle grinder, (i all ready beat the frame with a hammer to get scale off and find weak spots) then im going to use either a converter or rustolium then a good few coats of black paint.
Old 08-14-2010, 09:13 PM
eli85's Avatar
eli85
eli85 is offline
I used a chipping hammer on mine, then took the wire wheel to it. You will definetly find your weak spots with a chipping hammer.
Old 08-14-2010, 10:13 PM
CJM8515's Avatar
CJM8515
CJM8515 is offline
Knotted wire wheel in a grinder preferably but a drill will work well too.
After your done clean it off with brake cleen (to remove most everything left) then paint it some kinda rust proofing paint and then top coat. I like rustoleum rust reformer and satin black to top coat..
Old 08-14-2010, 10:16 PM
fordboy5894's Avatar
fordboy5894
fordboy5894 is offline
i would use a cold chisel. i used that on my rims when i broke them down and it worked like a charm
Old 08-15-2010, 03:27 AM
hatchet's Avatar
hatchet
hatchet is offline
thanks ill try a all try out all of those things.the rust is the worst near the rear shocks on the inner part of the frame just behind the rear shock mounts.i got alot off with a scraper.but its on both sides of the frame inner and outter guess I got a job cut out.if i had more time i would take everything off the frame and have the whole frame sandblasted at a local shop but its not really worth it.
Old 08-15-2010, 05:25 AM
Volvo92906's Avatar
Volvo92906
Volvo92906 is offline
I worked in a HD truck shop and we did this to the semis every few years. We used a needle scaler on the frame to break a lot of the rust/scale off and its very effortless and probably the easiest. Then you wire wheel the whole thing. You get it damn near stripped this way. Like everyone else said, you will find the weak spots as you move along. Afterward apply some paint and youre good for a while.
Old 08-15-2010, 07:07 AM
buck_'s Avatar
buck_
buck_ is offline
What do you guys mean by "weak spots"? Are you talking about punching through the frame?
Old 08-15-2010, 07:46 AM
Volvo92906's Avatar
Volvo92906
Yes. When a frame (or object) rusts it can get weaker. As metal oxidizes (rusts) you lose the solid bond. When you clean up the rust (usually heavy stuff, not just a light surface rust) you are taking off material that was part of a solid structure. If its really bad, you will notice spots that are thinner than others or even spots that go all the way through.
My buddy had some wheels on his truck that were so rusted that he could take a screwdriver and poke right through the wheel with it. Needless to say, they were replaced immediately.
Hope this helps. I tried to find the right words to explain it clearly.
Old 08-15-2010, 08:43 AM
eli85's Avatar
eli85
eli85 is offline
Never thought of a needle scaler but that would work great. But if the rust is as bad as you say you will probably find a place or two you go the whole way through. mine was the worst around the hangers and the bumper brackets. Also check out all the cross members. I had to replace the two that suported the rear tank. Most of them are simple enough to fabricate your own if your trying to stay on a budget.
Old 08-15-2010, 10:49 AM
F-350 Mud Digger's Avatar
F-350 Mud Digger
F-350 Mud Digger is offline
What I did was I took a wire wheel on an air drill and just went all over it, then I bought a quart of POR-15 and slapped it all over with a few coats. Now my frame looks brand new.
Old 08-15-2010, 03:28 PM
fordboy5894
i did that on my ranger. my f350 wasnt so bad so i just wire brushed it, chiseled a little, then used rustoleum rusty metal primer, paint on rustolluem black, black spray bomb, and 3 coats of clear and it came out mint (mind you the body was never taken off)
Old 08-15-2010, 05:11 PM
leavy20's Avatar
leavy20
leavy20 is offline
@mud digger, how much POR-15 did it take to cover the frame?
i am having a toss up between a base of POR or rustoleum. deciding factor will be price.
Old 08-15-2010, 05:15 PM
amr5080's Avatar
amr5080
amr5080 is offline
Needle scalers work very well. We use them on tractor rims all the time from the rust the the tire ballast causes.
Old 08-15-2010, 11:15 PM
F-350 Mud Digger
I bought the quart, I did 6 good coats, then I coated my plow 4 times. I also did my gas tank. AND I still have some left. It cost me $45 for the quart. $30 for a pint.
c2z4s9
17
01-08-2015 08:43 AM
curtk69
Paint & Bodywork
01-31-2013 11:23 PM
az3pqf
Appearance & Dress-Up
09-03-2010 06:39 PM
Fomoko1
66
06-21-2007 10:05 PM
sancochojoe
Paint & Bodywork
01-29-2004 08:40 PM
Quick Reply: how to remove rust on frame
