Transmission slipping - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 08-14-2010, 03:22 PM
'02strokerpilot's Avatar
'02strokerpilot '02strokerpilot is offline
'02strokerpilot is starting off with a positive reputation.
Unhappy Transmission slipping
Hey fellas, I have noticed a transmission slippage recently here's how it works:
in reverse, on a hill backing up the more pedal I give my truck the less power it is putting to the ground, almost like an e-brake is kicking on, more rpm's = less power? wtf?
in drive, heavy acceleration off the line it seems like the tranny isn't locking into gear, the truck moves but not like it used to, no "push you back in the seat" that it used to have. it is not as notieable in drive as it is in reverse. I could barely back out of my favorite fishing hole yesterday, Bull#!*%. I put a john wood VB in last fall and got the dp tuner right after that. I haven't been running any tunes lately just in case i have a real tranny issue, but its noticeable in stock mode too.
I searched forums and found one kinda similar, one guy suggested maybe his tranny filter was loose and letting air by? should I pull the pan and check to see if this is the case?
ps, no shuddering or anything, no squealing.
Thanks a ton guys!
Old 08-14-2010, 05:15 PM
mongo75's Avatar
mongo75 mongo75 is offline
mongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to all
Well, you could drop the pan to at least check first, but if it is shot and you feel he gears and bands are ok, you could have a shop (or yourself) put a new triple clutch TC in place of the cheap stock single clutch TC. If you need a whole new tranny, I would go with either John Woods, BTS, or in a pinch Ford sells a "heavy duty" 4r100 with a triple disc TC and strengthed internals for about $3000, and it comes with a 100k warantee to boot. You didn't say your mileage, but with regular towing and a heavy foot, these trannys usually aren't good past 150k miles (on average). Hell, I'm on my 3rd, the second one rebuilt by Midas or meineke (whoever the hell does trannys) only lasted 32k before my dumbazz blew it up LOL.....
Old 08-14-2010, 05:40 PM
mueckster's Avatar
mueckster mueckster is online now
aka Redneck Wrencher
mueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputation
Like Danny said, I would drop the pan and check the filter. It sounds like you are having low line pressure problems. A gauge connected to the line pressure test port on the left side of the trans would verify this.
Old 08-15-2010, 07:44 AM
bobbyrjw's Avatar
bobbyrjw bobbyrjw is offline
bobbyrjw is gaining momentum as a positive member of FTE.bobbyrjw is gaining momentum as a positive member of FTE.
What about using AE to test it?
I think that I am starting to have too much slippage, also.
I don't have AE, but can AE be used to help determine slippage?
Old 08-15-2010, 09:54 AM
mueckster's Avatar
Yes. You can monitor trans slippage with an AE. You can monitor the rpm difference between the input and output shaft sensors. It is listed in your drop down menu for your live data meters. Once the TC locks, you should see zero rpm slippage in an ideal situation. I see 0 to max of 4 rpms with mine. With the TC unlocked, it is normal to see a larger rpm difference due to the design of the TC.
Old 08-15-2010, 02:51 PM
jasonch's Avatar
jasonch jasonch is offline
jasonch is starting off with a positive reputation.
my TC is load, it rattles a ton. debating on rebuild or just driving it till its gone. the money pit is getting deeper. not sure if i will everf get out.
Old 08-15-2010, 04:48 PM
Bonanza35 Bonanza35 is offline
Bonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to behold
Sound like a tc for sure. These trans have weak reverse anyway. If you feel it in forward gear as well bite the bulet and put a trans in. You have a John Wood vb he usually credits you for that and will do the trans less that cost. Good luck, just don't get out on that road far or you may be sorry.
Old 08-17-2010, 10:09 AM
hey thanks for the help guys, my neighbor friend owns a trans shop, gonna run it by and have him test the pressure, depending on the outcome i will pull the pan and check it out. thanks again, hey, another Q for ya... can i have a shorter reverse gear put in like 2.5:1 or 3:1 area??? I have an uncanny ability to get my nose places I can only back out of. thinking about a locker in the rear too, any brand suggestions or are they all good? thanks again! oh 142,000 mile btw lots of heavy towing and lots of drag racing, pay to play i spose, lol
Old 08-17-2010, 12:11 PM
SpringerPop's Avatar
SpringerPop SpringerPop is online now
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
Why not consider a dirt-cheap mod that enables you to have 2WD, lo-range?
That would be lo-range, reverse, too.
Pop
Old 08-17-2010, 09:49 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
Quote:
No. Due to the way planetary gear sets work you would have to replace all the gears. Designing a new gear set is not an easy job. Cutting custom gears literally costs in the millions of dollars.
Old 08-30-2010, 08:51 PM
figured out my problem!!! My neighbor is a trans shop owner, he did some research for me and found that installing the accumulator body (improperly known as the valve body) from John Wood and not installing the full trans shift kit, the new accumulator body does not allow proper pressure in reverse to lock the torque converter, not slippage just no aftermarket "trick" spacer to accomodate the new accumulator body. makes me happy! now i am looking into the 2-low mod. this site kicks A%%!!!
thanks for the input guys!
Alex
2005 F350 4x4 problems and no reverse FordCamping 1999 to 2016 Super Duty 10 08-10-2012 10:42 PM
Transfer case problems jimjoebob99 1987 - 1996 F150 & Larger F-Series Trucks 8 12-04-2009 12:53 PM
Transfer case woes jimjoebob99 Clutch, Transmission, Differential, Axle & Transfer Case 2 12-01-2009 07:46 AM
C6 tranny all gears go in reverse. hawkrdr Clutch, Transmission, Differential, Axle & Transfer Case 2 03-31-2009 10:47 AM
help: my bronco 93 xlt totally blocks itself in reverse bronco93@Miami 1978 - 1996 Big Bronco 18 06-20-2008 12:46 PM
Tags
1967, 2000, 73l, automatic, camouflage, diesel, excursion, f250, f350, ford, sliping, slipping, transmishon, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
