How Do I Remove the Inside Drivers Door Handle
Old 08-14-2010, 10:43 AM
Daytona F1's Avatar
Daytona F1
Daytona F1 is offline
I need to remove the door opening mechanism located behind the inside handle on the driver's side. I figured out how to remove the pin on the handle and the three screws on the door but I can't find a way to get it down past the window mechanism.
Do I have to remove the window brackets first to get it out?
Thanks
51 F1
Old 08-14-2010, 11:39 AM
51PanelMan's Avatar
51PanelMan
51PanelMan is offline
Try raising the window and loosening the window mechanism. It's been a while since I did this procedure, but I don't think that you have to remove the window mechanism completely.
Old 08-14-2010, 12:01 PM
ZOOT's Avatar
ZOOT
ZOOT is offline
It's been a while for me as well, but I'm pretty sure you have to remove the glass off the brackets and out the access panel on the bottom of the door. Then you can get your arm up there. It's a real pain, not much room to move. Hope that helps.
Old 08-14-2010, 01:43 PM
Julies Cool F1's Avatar
Julies Cool F1
Julies Cool F1 is offline
Actually, you don't have to remove the glass to get the door latch mechanism out.
But as I recall, there is a little bit of maneuvering around when you are dropping out the mechanism. I usually roll the window all the way up and after taqking all the screws out of the latch, drop down the back of it first as you continue to pull the inside handle shaft/mount toward the back of the door, then pull the inside handle **** back and then down. You may have to roll the window down an inch or two to gain some clearance.
This is one of theose stupid things you can fight with for an hour and not get out, then let go of and it will fall out. Then figuring out how to get it back in is a pain.
rsh1966
06-19-2017 06:26 PM
hutchie
52
04-05-2017 12:01 PM
jc8825
1999 to 2016 Super Duty
50
08-04-2016 10:32 PM
william11
03-19-2016 12:11 PM
Marty Smilt
10-09-2010 12:23 PM
Quick Reply: How Do I Remove the Inside Drivers Door Handle
