Ford One Wire Alternator? 1959 w/292
Gentlemen- I currently have a GM one-wire alternator,want to know a couple things: a)Did Ford make a similar 1-wire alt.? b.)If so,which year,make and model should I specify to get the correct part?
I really want to change this for only one reason.I bought a nice polished stainless alternator mount so I could do away with the one I put together when I switched from the stock generator.It is functional,but rather pedestrian looking.Apparently,the bolt spread is wider on the Ford vs. Gm alternators,so I can't use the mount.
I would also consider a standard Ford alternator,if necessary,that would allow me to have a functioning idiot light again.Any help?Steve.
Ross,I do already have a Gm 1-wire installed.In fact,it's a 100 amp,nice looking one from Summit.It just won't work with the fancy stainless Y-Block-specific alternator mount I bought when I had the new motor installed.I'm trying to clean up the engine compartment a bit.
Havi,thanks ,I'll check out the link.
Steve (always have been,always will be)
FrankGRUN
Electrical Systems/Wiring
06-25-2016 01:01 PM
ajbremer
13
07-28-2015 06:24 PM
Tumblindyce
08-17-2009 11:24 AM
1959, 292, 59, alternator, conversion, f100, ford, gm, gm1wirealternatoridiotlight, idiot, light, mount, small, wire, yblock
