If you want some instructions on how to take it out, click this link (Terminator Engineering), go to the Tech link at the top, and there's picture instructions that will show you step by step how to get the HPOP out.
Got it out. Cleaned, installed new longer plug and torqued properly. Put it back in and I got tired. Plus I need to find my big torque wrench to sinch down the gear bolt. I read in another thread that you have to fill the HPOP with fresh oil. How or where do I do that?
There's a plug on the top right-hand side of the reservoir lid. Unbolt that to fill with oil. Only need to put in at most a quart, most likely 3/4 a quart. If you add more than that, it will just keep draining into the oil pan.
im try tring to put my hpop back after fixing it ... i took off my resivor do i need to fill it back up? how many in /lb do i torque down the gear bolt
