2008 Expedition Rear Halfshaft Nut - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 08-13-2010, 07:29 PM
steve2008 steve2008 is offline
steve2008 is starting off with a positive reputation.
Does anyone know what size is the rear Halfshaft Nut on the 2008 Expedition? I need to get a sucket but I cannot tell what size sucket I need. I have the Workshop Manual, but it doesn't tell me which size it is.
Old 08-15-2010, 09:24 PM
D-Rock D-Rock is offline
D-Rock is starting off with a positive reputation.
On my Cobra's IRS, it's a 36mm. Have not checked the Expy's bearing nuts yet, but I'll try to check it for you if I get some time this week.
Old 08-16-2010, 04:23 PM
Thank you. That was a good confirmation. I used adjustable wrench, I squeezed it tight around the halfshaft nut, I pulled it out carefully and I measured somewhere around 35 and 36. I thought it couldn't be 34mm for sure so it must be 36mm. At least now I can go and buy the right socket. But the fun I think is just beginning, trying to figure out how to pull the hub out. I think I'll rent the hub puller from O'Reilly's.
Old 08-16-2010, 04:37 PM
gddyup's Avatar
gddyup gddyup is offline
gddyup is gaining momentum as a positive member of FTE.gddyup is gaining momentum as a positive member of FTE.
Are you replacing the hub or are you just trying to replace the broken lugs? Usually you can hammer the lugs out and then replace them...
Old 08-16-2010, 06:19 PM
eddiemoney eddiemoney is offline
eddiemoney is starting off with a positive reputation.
Quote:
Okay you got me, whats a sucket
Old 08-16-2010, 07:41 PM
As far as the "sucket" (socket) ... OK ... let's say spelling is not my strong side and I forgot to run the post through spell check.
But all I want to do is replace the broken studs and I'm trying to find the easiest way of doing it. One option is to get the Hub out. Another option is to get the parking brakes out without getting the Hub out. I've never done this before so I don't know which way would be better or easier, but something has to come out because there's no room for the studs.
Any suggestions would be appreciated.
Old 08-16-2010, 08:37 PM
Take the entire thing off, it generally saves more time and there is less stuff to break.
04 alternator......major pain in the .... fordboy67 Escape & Escape Hybrid 3 03-29-2016 05:52 AM
2008 Edge ABS Tone Ring ricviv Crossovers 3 03-10-2016 03:40 PM
Rear hub jawdoc 2007 - 2014 Expedition & Navigator 3 09-30-2015 02:15 PM
Rear hub jawdoc 1997-2006 Expedition & Navigator 2 09-30-2015 09:41 AM
Front left noise Nader 1999 - 2003 7.3L Power Stroke Diesel 10 09-08-2015 03:53 PM
Tags
1997, 4x4, driveshaft, expediton, f150, ford, half, halfshaft, lincoln, navigator, nut, ranger, rear, shaft, size, thread
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
