2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
rear roof heat??? URGENT
Old 12-21-2011, 10:52 PM
jake00's Avatar
jake00
jake00 is offline
FTE is my crack
Hey guys, thanks for the help, We're leaving on a trip at 10 am...
the manual shows the "rear controls" as 2 ***** that the left one is the fan level the right one is the "roof/all/floor" control.....
But, in my expy the right **** is a temp ****... heat (twisted clockwise directs it to the floor) cool (twisted counter clockwise directs it to the roof)
Can I get heat to come out of the roof?
Old 12-22-2011, 01:34 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
yes you can
you should have 2 ***** on the rear of the center console. 1 **** is the temp selector, the other **** is the fan speed. It will blow ambient temp air, or heat out the roof unless you turn on the Rear A/C on the dash.
on my Expy the Hot and/or cold comes out under the drivers/passenger front seats, and it comes out from the top vents.
Old 12-22-2011, 10:40 AM
berry1234's Avatar
berry1234
berry1234 is offline
Note, I have found if you peg the hear to 90 on the front controls it will not blow out the rear top vents. I guess it doesn't want to 'scald' the people with the hot air. Move it to 85 and it seems to work fine.
Old 12-30-2011, 10:03 AM
cstanley44's Avatar
cstanley44
cstanley44 is offline
I dont get any air moment from the rear roof vents when the heat is on.
AC blows cold.
When I switch to HOT, I can still hear the blower out back, but no air comes out.
Must have a stuck vent flapper or something.
Old 12-30-2011, 10:29 AM
berry1234's Avatar
berry1234
I would say so. Work the vent controls with the front set to Rear so that the rear controls work. Maybe you can unstick them. listen for the motor trying to move vents.
Old 01-01-2012, 10:04 PM
jake00's Avatar
jake00
jake00 is offline
FTE is my crack
I can't get heat out of the rear roof by using the rear controls
Old 01-02-2012, 12:32 PM
chuck s's Avatar
chuck s
chuck s is offline
In the rear heat comes out the floor vents, AC or outside air out of the ceiling. At least on mine. As I would expect. Depends on the temperature setting.
-- Chuck
Old 01-05-2012, 03:36 PM
Blacknav's Avatar
Blacknav
Blacknav is offline
-- Chuck
^ Is that normal? I've been racking my brains cause I can't get hot air to blow out of the roof vents.
If I set the controls to cold it blows out fine from the roof, but if I set it to hot the roof vents turn off and it blows hot air from the floor vent in teh third row.
I've left the temp setting in the middle to get a bit of warmth from the top vents.
Never really noticed it until recently so I always thought something was wrong, but now I'm not so sure
Old 01-05-2012, 03:54 PM
cstanley44's Avatar
cstanley44
Who knew!
I have the same functionality as you, thought for sure heat should blow out of the roof, but I guess not.
Old 01-06-2012, 10:19 PM
mtondreo's Avatar
mtondreo
mtondreo is offline
Was kind of following this. Apparently this is different on the 3rd gens. My 06, I can crank the heat all the way over and it will still blow from the roof or wherever I tell it to. I have not payed attention on the 3rd gens to see if they have gone to a more automatic system-but I can definitely crank the heat through the roof in mine. I verified this morning just to be sure.
Old 01-09-2012, 02:03 PM
Blacknav's Avatar
Blacknav
Blacknav is offline
Yea, I had a 98 Navi before and it would just do what I told it. Which is why I assumed somethign was wrong when my '07 didn't do the same thing.
Glad I didn't pay ford to diagnose and charge me to tell me that,
Old 01-09-2012, 11:14 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
weird, maybe mine is screwed up?
I've definately gotten hot air out the top before....granted it doesn't get used a ton out here, so I really don't care. Long as the A/C works properly
king-david
1997-2006 Expedition & Navigator
10-26-2018 07:15 AM
Frdtrkrul
19
01-09-2017 03:08 PM
03chateau150
12-02-2006 11:32 PM
97astar
Aerostar
07-08-2004 06:47 PM
jmailand
11-13-2003 12:14 PM
Quick Reply: rear roof heat??? URGENT
