2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
2008 Expedition Rear Halfshaft Nut
Old 08-13-2010, 07:29 PM
steve2008's Avatar
steve2008
steve2008 is offline
Does anyone know what size is the rear Halfshaft Nut on the 2008 Expedition? I need to get a sucket but I cannot tell what size sucket I need. I have the Workshop Manual, but it doesn't tell me which size it is.
Old 08-15-2010, 09:24 PM
D-Rock's Avatar
D-Rock
D-Rock is offline
On my Cobra's IRS, it's a 36mm. Have not checked the Expy's bearing nuts yet, but I'll try to check it for you if I get some time this week.
Old 08-16-2010, 04:23 PM
steve2008's Avatar
steve2008
Thank you. That was a good confirmation. I used adjustable wrench, I squeezed it tight around the halfshaft nut, I pulled it out carefully and I measured somewhere around 35 and 36. I thought it couldn't be 34mm for sure so it must be 36mm. At least now I can go and buy the right socket. But the fun I think is just beginning, trying to figure out how to pull the hub out. I think I'll rent the hub puller from O'Reilly's.
Old 08-16-2010, 04:37 PM
gddyup's Avatar
gddyup
gddyup is offline
Are you replacing the hub or are you just trying to replace the broken lugs? Usually you can hammer the lugs out and then replace them...
Old 08-16-2010, 06:19 PM
eddiemoney's Avatar
eddiemoney
eddiemoney is offline
Okay you got me, whats a sucket
Old 08-16-2010, 07:41 PM
steve2008's Avatar
steve2008
As far as the "sucket" (socket) ... OK ... let's say spelling is not my strong side and I forgot to run the post through spell check.
But all I want to do is replace the broken studs and I'm trying to find the easiest way of doing it. One option is to get the Hub out. Another option is to get the parking brakes out without getting the Hub out. I've never done this before so I don't know which way would be better or easier, but something has to come out because there's no room for the studs.
Any suggestions would be appreciated.
Old 08-16-2010, 08:37 PM
eddiemoney's Avatar
eddiemoney
Take the entire thing off, it generally saves more time and there is less stuff to break.
The_Ford_Driver
Aerostar
03-08-2021 12:33 PM
SVandal
05-07-2017 03:08 PM
jawdoc
1997-2006 Expedition & Navigator
09-30-2015 09:41 AM
RojoStar
Aerostar
23
09-20-2012 12:09 PM
Justmill3
06-03-2004 03:41 PM
Quick Reply: 2008 Expedition Rear Halfshaft Nut
