Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 08-13-2010, 12:06 PM
F350-6's Avatar
F350-6 F350-6 is offline
Garage is empty, add now
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
What causes the battery light to come on?
Battery light came on a week ago for a few minutes. I stuck the gauge in and started watching voltage and everything was fine with no more issues or lights until yesterday morning. Then I had less voltage with the truck running then with it off. No voltage at all from the alt.(and the battery light came back on). So I waited till Autozone opened up and got my "lifetime" alternator swapped out for free. Stuck it in and was on my way.
130 miles later that afternoon, the battery light comes on again and I'm showing 13.3 volts. So I swing by autozone to get it checked and they find a dead cell in one battery. We have the discussion about how diesel batteries should be replaced in pairs so they decide to give me 2 new batteries for a warranty exchange. Change them in there parking lot and as I'm leaving, the battery light comes back on. Get the alternator tested and it shows pass. I also had them bench test the alternator before I took it home the first time to be safe.
Still showing 13.65 - 13.85 volts while driving around. Hooked up jumper cables to a tractor last night and voltage jumped to 14.2. Cleaned the cable connections. Battery light still comes on and goes off rather frequently. RPM's have no effect since it often comes on when cruising down the freeway.
Suggestions or thoughts as to what's going on? For the record, the alt. & battery combo lasted 2 years. The stickers on the old batteries were labled 7/08. The stickers on the new batteries are labled 7/10.
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 435,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
  #2 (permalink)
Old 08-13-2010, 12:16 PM
Shake-N-Bake's Avatar
Shake-N-Bake Shake-N-Bake is offline
1999 Ford F-250
Shake-N-Bake has a brilliant futureShake-N-Bake has a brilliant futureShake-N-Bake has a brilliant futureShake-N-Bake has a brilliant futureShake-N-Bake has a brilliant futureShake-N-Bake has a brilliant futureShake-N-Bake has a brilliant futureShake-N-Bake has a brilliant futureShake-N-Bake has a brilliant futureShake-N-Bake has a brilliant futureShake-N-Bake has a brilliant future
Might not have any effect at all....but have you checked the cable connection at the starter? Maybe it's a little loose?
Just taking wild stabs just in case you didn't already think of this.
__________________
Greg
Alvin ('99 F-250 306k CC 4x4 XLT PSD red)-Theo ('00 F-250 202k CC 4x4 Lariat PSD white)-Simon ('00 F-450 197k CC Lariat white)
  #3 (permalink)
Old 08-13-2010, 12:38 PM
merccougar93's Avatar
merccougar93 merccougar93 is offline
merccougar93 is starting off with a positive reputation.
possible a bad ground at the block, maybe loose or corroded. Other than the starter connection, im scratchn my head.
__________________
Chris 1979 F350 330FE, NP435 LWB
1978 F150 351M 4x4, 3 spd AUTO, SWB
  #4 (permalink)
Old 08-13-2010, 12:48 PM
F350-6's Avatar
I'll double check the connections, but I'm not having any symptoms other than the light on the dash. I've been watching the voltage reading while driving and it's not jumping around or acting funny when the light comes on, and it doesn't do anything different if the light goes off 10 minutes later.
I'm guessing it's one of those internal gadgets in the alternator and not a voltage issue. If I start seeing fluctuating voltage, I'll get it swapped out, but so far it seems to be acting normal on the voltage side.
__________________
Chris
  #5 (permalink)
Old 08-13-2010, 12:53 PM
tdpower's Avatar
tdpower tdpower is offline
2000 Ford F-250
tdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to behold
You mentioned before that you were having problems with your AC. I wonder if that could have anything to do with it? Maybe try to unplug the ac electrical connector. Have you gone through all your fuses? There is also a diode for your ac clutch that you might want to check. Listed as #37 in the engine fuse box in my owners manual. Sounds like it might be a pain to track down. Just throwing out some thoughts.
  #6 (permalink)
Old 08-13-2010, 12:58 PM
farmb0y's Avatar
farmb0y farmb0y is offline
farmb0y has a great reputation on FTE.farmb0y has a great reputation on FTE.farmb0y has a great reputation on FTE.farmb0y has a great reputation on FTE.
All I can suggest is to go thru all your connections to the batteries, starter and grounds and make sure the are clean and the cables are in good shape. May be worth testing the cables, even through they have continuity they may not be in shape to carry the required current.
__________________
'08 F350 4x4 CCSB Lariat 6.4L PSD
DPF/EGR delete, KEM Tunes, Air bags, hitches and a big fuel tank.
  #7 (permalink)
Old 08-13-2010, 01:19 PM
bama29fan's Avatar
bama29fan bama29fan is offline
bama29fan has a very good reputation on FTE.bama29fan has a very good reputation on FTE.bama29fan has a very good reputation on FTE.
where are all the major grounding points?
__________________
SHAWN : PAA# 102 --
2012 F250 CC Lariat FX4 / White Platinum / 3.55e
2009 Outback Sydney 310BHS
Gone but not forgotten--2001 / 7.3L / 2wd / CC/ lwb / manual trans / dually / 160K
  #8 (permalink)
Old 08-13-2010, 03:14 PM
Ponyboychris's Avatar
Ponyboychris Ponyboychris is offline
Hit it!
2002 Ford F-350
Ponyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud of
ChrisMPorras
I guess I got lucky. My battery light = dead alternator.
__________________
Chris
2002 F350 XLT, 7.3L CC 4x4, SRW, Autometer Ultralites, DP TUNER, BTS Trans, 6.0 tranny cooler, F650 dash, AIS w/zoodad, Warn Hubs, 4" MBRP exhaust, '08 rear end cover, Foil Delete, Heated Tow Mirrors, AIH Delete, Homemade CCV mod., Bilsteins.
The Silver Bullitt PAA# 24
  #9 (permalink)
Old 08-13-2010, 04:02 PM
megawatt00's Avatar
megawatt00 megawatt00 is offline
megawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputation
Check the connector that plugs into the alternator Chris. Like I said earlier on my way back from TN my battery light did the same thing. I pulled over and cleaned the battery clamps and posts. All set. Drove approx another 50 miles and the same thing happened. We pulled over again thinking that I needed to get batteries after the alternator incident, it turned out that upon wiggling the connector the voltage would jump from anywhere from 12.1 to 14.2 volts. I ty wrapped the cable to take any pressure off the connector and it has been fine ever since.
__________________
Jim
01 F350 DRW, Autometer Gauges, Custom CAI with Petes Cover, 6" Miter Stacks, 38R Turbo, Casserly SS Injectors, Live tuned by DP-Tuner (F6) , and a bunch of other stuff some show, and some go. PAA #14
www.roadsidehelpnetwork.org
RIP Robin Gone but not forgotten....RIP Mark.. I'll never forget you!!
  #10 (permalink)
Old 08-13-2010, 07:09 PM
ncm0008 ncm0008 is offline
ncm0008 is starting off with a positive reputation.
Quote:
I feel like I might have the exact same problem as you and mine just started 2 days ago. Came on and went off pretty quickly the first day, then stayed on the whole next day. Today I go check voltages at the batterys and the alt and get the same reading, lower voltage with the truck running than with it off. WTH??? I also saw where someone posted you having A/C issues, I am having some of those too so I'm going to go find that thread as well. This SUCKS, its HOT in San Antonio with no A/C!!! LOL Let me know what you find out, I'm gonna take this to the brand spankin new autozone and have it tested and probably throw a new alt at it.
Nick
  #11 (permalink)
Old 08-13-2010, 07:22 PM
clem1226's Avatar
clem1226 clem1226 is offline
clem1226 has a great reputation on FTE.clem1226 has a great reputation on FTE.clem1226 has a great reputation on FTE.clem1226 has a great reputation on FTE.clem1226 has a great reputation on FTE.
Might want to try something like Dan did. Check out post number 5
link to other forum post
__________________
Steve
"put your purse down and logger up" Steve C Clemenson AKA E RolumTruckem (ECV 62). RIP June 9 1955 to June 16 2011.
  #12 (permalink)
Old 08-13-2010, 07:42 PM
tdpower's Avatar
2000 Ford F-250
Is this a re manufactured alternator? Why don't you sweet talk the wife and swap.....
  #13 (permalink)
Old 08-13-2010, 08:33 PM
F350-6's Avatar
Quote:
Thanks Jim. I started playing with that but my AC guy called so I got side traced with more important issues.
Quote:
Nick
I had to replace the clutch on my AC. It's been working flawlessly since. Of course the AC on my house is dead right now. Dealing with the truck AC was much easier.
I've been thinking about that, but am not sure it will help my situation. Like I said, I'm not getting any fluctuation in the voltage readings.
Quote:
She'll probably make me clean my engine before I'm allowed to put it in, but that's a pretty good idea. I might try that and see if it helps.
__________________
Chris
  #14 (permalink)
Old 08-13-2010, 10:20 PM
clem1226's Avatar
on the up side it's cheap and it couldnt hurt...wish I had some better insight.
__________________
Steve
  #15 (permalink)
Old 08-13-2010, 11:06 PM
Ah, the home AC, that sucks way worse than my truck ac being out. Good luck!
I was reading somewhere else that the truck AC may have issues if the clutch is old and the voltage drops too low. Hoping I don't have to replace both right now.
You having pretty good luck with the autozone alt other than this incident? Cant decide if I want the autozone one or the oreilly one even though I know they probably both come from the same manufacturer.
Tags
2002, 73, alternator, battery, charging, coming, expedition, f150, f350, ford, freestyle, intermittent, light, make, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
