1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
How removing the bed ?
Old 04-23-2011, 04:37 AM
TobiasR.'s Avatar
TobiasR.
TobiasR. is offline
hi
I need help to removing the bed from my F250, there are 4 screws is that all ? and how heavy is the bed is it possible that four people can remove that ?
Thanks a lot
best regards
Old 04-23-2011, 05:30 AM
BareBones's Avatar
BareBones
BareBones is offline
Four people is fine. Any potential problem lies in removing the bed bolts, which are a notorious PIA. My bed has 8 bolts, and I wound up having to grind two of them off.
Replacement bolts are torque-to-yield, and aren't exactly cheap.
Old 04-23-2011, 06:38 AM
pbeering's Avatar
pbeering
pbeering is offline
Spray the bed bolts with PB Blaster and allow it to soak. (from the bottom) Have a torch and several big torx bits available, as you will likely break one (or more) (of the bits) Size varies a bit by year. Sometimes you can weld a nut to the bolt top.
There are a number of things attached to the bed, including the fuel fill. Again, depends a bit by year.
4 folks who have had their spinach can lift it off.
When you put it back together paint the bed bolts, or the grade 8 replacements, with anti-seize.
While the bed is off rinse off the frame and paint it with POR-15 or equivalent.
Old 04-23-2011, 07:50 AM
mikemass's Avatar
mikemass
mikemass is offline
Curious? Why are you removing the bed? Are you doing some kind of modification?
Old 04-23-2011, 10:47 AM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
There are three screws inside the fuel door, all the wiring for the tail lights, and pulling the back bumper makes it easier to slide backwards and off.
I used T55 torx bits IIRC.
Old 04-23-2011, 11:22 AM
cartmanea's Avatar
cartmanea
cartmanea is offline
The bits are actually Torx-Plus, not regular Torx. Torx-Plus has thicker, stronger lobes, which is why regular Torx breaks in this application. The stock bolts are self tapping into the clips, so they usually gall and are near impossible to remove without cutting them from underneath.
Old 04-23-2011, 12:16 PM
TobiasR.'s Avatar
TobiasR.
TobiasR. is offline
thanks for your help and replys
I sprayed in the screws with rust off and that was very helpful. One Torx bit is broken (home improvement store) and now I have to wait until Tuesday (Easter at the moment).
For your question "mikemass" No modification the border is a little bit twisted and so it is easier to remove the bed and then repair this.
But one question did I have @texastech_diesel what did you mean with IIRC ?
Thanks a lot
best regards
Old 04-23-2011, 12:50 PM
longview1's Avatar
longview1
longview1 is offline
IIRC=If I recal correctly.
Old 04-23-2011, 02:11 PM
TobiasR.'s Avatar
TobiasR.
TobiasR. is offline
@longview1
thanks a lot, I´m a bit excited
best regards
Old 04-23-2011, 02:25 PM
KoolAidMan888's Avatar
KoolAidMan888
KoolAidMan888 is offline
i just dida bed swap.. i said screw the unbolting went and got new bed bolts from ford and just torched off the only ones. i actually put the new bed on with myself and a buddy we picked it up and put it on.. wat a fun time.
Old 04-23-2011, 09:36 PM
BareBones's Avatar
BareBones
Actually, it only takes one person to lift the bed. Well, one person and two engine hoists....
Old 12-01-2016, 10:05 AM
Lex2002's Avatar
Lex2002
Lex2002 is offline
I think I love you.... Thanks for this tip!
Old 12-01-2016, 12:40 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
The bits are actually Torx-Plus, not regular Torx. Torx-Plus has thicker, stronger lobes, which is why regular Torx breaks in this application. .
ditto,,,what he said
Old 12-12-2016, 01:55 PM
Lex2002's Avatar
Lex2002
Lex2002 is offline
They are Torx Plus 45. Which, BTW, shattered into bits after removing 2 of 8 bolts.
Just cut them off and save yourself from destroying a $10 impact Torx. Youll need a new set anyway. Dorman sells 8 of them for $38 on amazon.
KWDAILYD
2017+ Super Duty
02-15-2018 10:00 AM
gumshoe
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
01-22-2018 01:43 PM
Glenn54
07-30-2017 11:05 PM
rockymtns
Fifth Wheel & Gooseneck RV Towing
06-30-2017 07:38 AM
jeffie_3
13
05-21-2016 08:59 PM
Quick Reply: How removing the bed ?
