anyone with a dually 5 sp and 4.30 gears
if any of yall have either 4.10 or 4.30 gears in your truck with a 5 speed
can you tell me what rpm you are running at 65 ?
i checked my door code and it comes out to a 4.10 ratio
but at 65 im running just a hair over 2500 rpm and if i use that on the calculator at ringpinion.com it comes out to a 4.30 rear
so im trying to figure out which one i have
any help would be appreciated
on
how to correct your speedo:
https://www.ford-trucks.com/forums/9...ler-tires.html
(i searched for your previous posts to see you have a '93.)
you'll want to do that so not only will your speedo be back on,but also your odo,for correct fuel mileage readings and maintenance routine.
or uses spacer's between the rims.
example:
http://cgi.ebay.com/ebaymotors/1-2-A...Q5fAccessories
if needed.he'd have to post his wheel #'s.
example:
aight here is what i just got on the way home
4th gear 2000 rpm 40 mph on the gps pretty close on the dash
4th gear 2500 rpm 50 mph on the gps little farther off on the dash
odo seems to be pretty close, i know that its just a little over 30 miles driveway to driveway between work and home and it shows like 30.4 on the odo
right now im not as concerned about the speedo or the odo, well not really concerned about any of it, but if i do have 4.38 in the rear i want to get them changes to 3.73s to get better fuel mileage on the road.
on
its a sterling full floater for sure with a 4.10 rear gear ratio.
the only options were 3.55 or 4.10
you can swap the rear axle for another DRW pickup axle (make sure its not a cab and chassis rear axle) then sell yours.you'd be looking for a DRW pickup axle w/3.55's.
or you could have a set of 3.55's installed into your current axle.
4.10's with 30" tall tires is a great hauling gear.so depending on the camper your thinking about,you may or not want the 4.10's.
running empty to work and back is kinda useless to have such steep gearing with short tires, though if your thinking about a 5th wheel,you'd wish you had them.
if your planning on a carry on camper,id switch to 3.55's for sure.
