1987 F350 axle code - Ford Truck Enthusiasts Forums
1987 F350 axle code
Old 08-12-2010, 07:40 PM
va150's Avatar
va150 va150 is offline
va150 is starting off with a positive reputation.
1987 F350 axle code
The axle code in the door jamb says 49, I believe it is a 3.55 axle. Can someone verify for me? Thanks!!
Old 08-13-2010, 03:53 AM
phoneman91's Avatar
phoneman91 phoneman91 is offline
phoneman91 has a good reputation on FTE.phoneman91 has a good reputation on FTE.
Quote:
Code 49 should be a 3.55 with open differential and 7400 pound axle capacity.
Old 08-13-2010, 09:35 AM
va150's Avatar
Thanks, that's what I thought.
Looking for axle ratio for 1958 F-600 with axle code 62 KLEO1480 1957 - 1960 F100 & Larger F-Series Trucks 2 03-02-2013 07:53 AM
Axle Codes 1972RedNeck 1973 - 1979 F-100 & Larger F-Series Trucks 7 05-31-2012 12:33 AM
axle codes revans9295 1987 - 1996 F150 & Larger F-Series Trucks 4 04-26-2012 11:40 PM
Axle Code "35" = ? go2toa 1987 - 1996 F150 & Larger F-Series Trucks 18 11-24-2005 05:46 PM
Axle Code 31 cannonfodder Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 07-19-2004 10:50 AM
Tags
19, 1987, 1987f350, 87, axel, axle, axles, code, codes, f250, f350, ford, front, rear, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
