Draining the fuel/water separator on an '03 6.0 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-12-2010, 06:16 PM
thralkhan thralkhan is offline
thralkhan is starting off with a positive reputation.
Ok, silly newbie question, but I'm having a hard time finding the info I need. I have a 2003 F250 6.0l Lariat Crew. It's getting time for me to drain the fuel/water separator, but I don't know where it is.
My Haynes is very vague stating there's a drain hose under the truck. Someone else said the separator is located under the driver's door and to use a hex to remove the plug and drain it entirely.
First, where is it?
Second, is there a plug I remove and let it all drain, or a valve I open until fuel starts coming out?
Anything else I might need to know?
Thanks!!!
Old 08-12-2010, 08:26 PM
sammy77's Avatar
sammy77 sammy77 is offline
sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.
First, where is it?
Thanks!!!
Its on the frame(left side) Just behind the primary Fuel filter. Its a 6mm plug. Be advised they have a tendancy strip.
Old 08-12-2010, 08:28 PM
sandmanf250 sandmanf250 is offline
sandmanf250 is gaining momentum as a positive member of FTE.
this can be a problem to the uninformed public. if you slide under your truck on the drivers side you will see the filter hous ing in the frame rail.it has a 6mm allen head plug in a pot metal housing. a possible problem because the whole setup is potmetal and requires very gentle
handling as it will strip out in an instant if you try to force any thing. the easiest. way i found was to take the whole unit off the truck and put it on the bench.after a long soaking with p-b blaster i still stripped that stupid pot metal . so with a chisel and some delicate hammering i was able to get the plug out replaced it with brass unit sold on this website.take the time to clean the water in fuel section . if you have a 4 x 4 drop the front driveshaft as it makes it easier.
Old 08-12-2010, 08:47 PM
sammy77's Avatar
I wasn't so lucky. I ended up replacing the cover and installed the updated plug
Old 08-13-2010, 05:13 AM
Thanks for the responses.
Could someone post the link or tell me where to get the brass plug?
Thanks.
Old 08-13-2010, 10:48 AM
sammy77's Avatar
Thanks.
Here you go... www.partsguyed.com
Old 08-14-2010, 02:43 PM
awesome, thanks for the link!
Ok, here's another question, a little off-topic.
Does anyone where to get a large capacity oil drain pan? I've only seen up to 15 quarts, and then Blitz has a 58 quart.
I'd like to find something like 20 qts, that I can close up and transport for draining. Any suggestions? Getting one at 15 qts is cutting it a little too close for me.
Thanks
Old 08-17-2010, 02:18 AM
snakeside snakeside is offline
snakeside is starting off with a positive reputation.
I would take the sensor out and clean the pathways or replace it, u should also replace both fuel filters at the same time
Old 08-17-2010, 09:37 AM
jim6liter's Avatar
jim6liter jim6liter is offline
jim6liter is starting off with a positive reputation.
Thanks
I use an old 5 gallon gas jug.With the Fumoto valve,oil change is a snap.
Old 08-18-2010, 08:06 AM
Fumoto valve? What's that? (edit: I just looked it up. I think I'll order one myself...looks like the F111N)
Another question on draining the fuel/water separator; how much fuel/water can I expect to drain? I just want to make sure I have the right size container. I'm not sure if I should use a mason jar or an old 1 gallon fuel tank.
Thanks
Old 08-18-2010, 09:26 AM
jim6liter's Avatar
Thanks
I cut the top off a two liter bottle.If you cut it right it will fit right up there and will catch all fluid.
How to drain water from fuel/water separator in a 7.3 PSD van? SweetBearCub 1968-2013 Full Size Vans 1 08-07-2015 01:17 AM
HELP FAST!!! fuel/water separator drain how much? Coors Man 6.7L Power Stroke Diesel 8 07-18-2015 08:41 AM
Can you drain the DFCM with a full tank? Ricohman 6.7L Power Stroke Diesel 4 06-19-2015 05:50 AM
7.3L Fuel/water separator leak CLSE 1999 to 2016 Super Duty 4 02-22-2011 05:45 PM
Changing the lower fuel filter 6.0L frame rail ExcusionBeatsAll 6.0L Power Stroke Diesel 2 04-03-2004 04:48 PM
Tags
03, 04, 1994, 60, deisal, drain, duty, ford, fuel, gas, location, separator, seperator, super, v8, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
