I beam quize - Ford Truck Enthusiasts Forums
Washington Chapter Washington Chapter
Join Chapter, Leader: Yahiko
I beam quize
Old 08-12-2010, 07:07 PM
PooreBoy's Avatar
PooreBoy PooreBoy is offline
PooreBoy is starting off with a positive reputation.
I beam quize
Who knows who holds the paten on drop I beams,not the retail outlet the "Paten holder name"
Old 08-12-2010, 09:36 PM
caseys's Avatar
caseys caseys is offline
caseys has a good reputation on FTE.caseys has a good reputation on FTE.
Quote:
Patents generally expire between 17 to 20 years from date of issue. More likely than not the patent on the original drop I-beam is past the expiration date. The original patent applicant can be located however.
What particular year are you interested, and the application use, since there has probably been different modifications to the patent?
Old 08-13-2010, 12:51 PM
PooreBoy's Avatar
Paten
Well I'm looking for 1977 I figure if I can find the plans on the paten I can make my own I-beams. Planing to pull front clip today and see what I can and can't do.
Old 08-13-2010, 03:40 PM
PooreBoy's Avatar
i'beam
do you know if the ibeams are cast iron or cased steel?
Old 08-13-2010, 04:13 PM
caseys's Avatar
Not sure I understand where you are taking this project, but see if this helps:
Fabricated front axle I-beam
Old 08-13-2010, 05:54 PM
PooreBoy's Avatar
nice
I knew they were out there some where.
Thanx!
Dan
Old 08-13-2010, 10:27 PM
caseys's Avatar
Thanx!
Dan
Dan,
Glad I could help...
Casey
Old 08-14-2010, 12:31 PM
PooreBoy's Avatar
k
Thanx a bunch,now if I can just get my printer work Rrrrrrrrrrrrrrrrrrr.
Old 08-14-2010, 01:35 PM
PooreBoy's Avatar
Casey,
Can you tell me how to change my album picture? the main one that you can click on to open album.
Old 08-14-2010, 08:07 PM
caseys's Avatar
Casey,
Yes sir, I can:
See the blue ribbon line across the top of the forum page... to the far left is "User CP"... click that.
On the left side column go down till you see "Pictures & Albums"... click that.
Chose the album to open.
Of the pictures in that album, click on the one you want to use as an album cover and open that picture.
At the bottom right of the picture you will see "Edit Picture"... click that.
Under you picture you will see a circle "this is your album cover"... click that.
Now click the button to "Save Changes".
There ya go.
Old 08-16-2010, 10:58 PM
PooreBoy's Avatar
Thanx
i just wanted to give thanx to Casey for his help. I just got a call from my fab guy and he is going to make me drop beams for $230 out of 1/2 thick steel. We still have to take some serious messurments,but all in all $230 is killer.
Thanx
Casey
Much love to you my man!
Old 08-17-2010, 11:14 AM
caseys's Avatar
Thanx
Casey
Thanks, appreciate the kudos. I will give ya crap now and then but will also find the information you need.
Pm'ed ya back.
Hi Beam indicator oft 1973 - 1979 F-100 & Larger F-Series Trucks 9 10-17-2014 09:46 PM
99 F250 SD CC 7.3 high beams don't work Slyder22 1999 to 2016 Super Duty 4 07-05-2013 03:13 PM
i-beam drop brackets marioc956 Offroad & 4x4 13 03-21-2008 05:39 PM
HELP! stock harass bulb- which wire is low beam ? YOMAN 2004 - 2008 F150 4 02-10-2006 10:31 PM
drop beams tgowers 1967 - 1972 F-100 & Larger F-Series Trucks 1 01-31-2006 01:23 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
beam, beams, dropping, f100, ford, front, ibeam, make, plans, thickness
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
