New2Me '81 F150 Custom Explorer Pkg A
Hi Everyone,
I’m a newbie to the forum and Ford pickups. I recently inherited two Ford pickups, this one and a 91 F350 Crew Cab 4x2. I was thinking about just selling this one but I started driving it and finding out things about it and now I’m thinking about keeping it around. I've known this pickup since about 1983-4.
It has not been driven much in the last few years but it is registered with out of state plates (Idaho, pretty rust free) and I’ve been driving it for about the last month on a daily basis.
This is what I’ve found out about it so far and would like some help clearing up the questions I have.
1981 Ford F150 Custom 4x2 Pickup:
GVWR: 5450 pounds
Wheel Base: 133’
Type-GW: F151 - What does this mean?
Body: MT4 - What does this mean?
Manufactured 3/81 Twin Cities Assembly Plant, still has sticker in window<O
VIN: 1FTDF15E6BPA64029
1 = USA
F = Ford Motor Company:
T = Truck (Complete Vehicle)
D = 5,001-6,000 lbs
F = F-series
15 = F150
E = 4.9L I6 Gasoline
6 = Check digit (ignore)
B = 1981 model year
P = Twin Cities assembly plant
A64029 = Consecutive build number
Current Mileage: 117,334 (Just getting broke in ;-)
Motor: 300 cubic in (4.9 liter ) inline 6
Transmission: Code F: 4 Speed Manual Transmission with no overdrive
Rear Axle: Code 13: Ford 9" 2.75 ratio
Color: On the door jamb it has 8A (This Appears to be a 1980 Color (Dark Chamois Met) There is no 8A Paint code listed for the 1981 model year. I’d always thought it was painted 5G - Dark Caramel Met
Explorer Package A:
1: Explorer Tri Color Tape Stripe (Bodyside and tailgate) in three Color Choices
2: Explorer Bedside nameplate
3: Explorer Hood Ornament
4: Sport Wheel Covers
5: Bright Rear Window Molding
6: Wheel lip Molding
7: Chrome Grille
8: Chrome Tailgate Release Handle
9: Custom Trim Series Avaliable in choice of:
9A: Unique Plaid Cloth and Vinyl – Nutmeg
Other Options: Original to vehicle
Power Steering
Power Brakes
Aux. Fuel Tank
Under hood Accessory light – not able to retract the cord
Sliding rear Window
Map Lights – not currently working
Under dash lights
AM Radio – not working
Cargo Light
Other Options: Added Later
Saddle Blanket seat cover – (needs to be replaced, seat looks like new)
Shell – Added shortly after pickup was bought new – needs to be gone, maybe replaced
Tachometer – Original Equipment from 1985 Bronco – brought off ebay but not installed yet
Electric Brakes
Work Done On Pickup
2008 - New Clutch
2008 - New Tires
2008 - New Muffer / Exhaust
2008 - New Starter
2010 - Dome Light, Underdash Lights, Turn Signal Lights
Needs / Repairs:
Replace Dome light lens cover
Brake work (right rear not working right)
Tune up (High CO levels on emissions test)
Dash Pad (imagine that)
Install Tachometer
Replace Saddle Blanket Seat Cover
Repair Map Lights – not working
Repair / Replace Under Hood Light – Cord will not retract
Oil Change - Oil looks OK but know the last time it was done
repair Screw holes from CB radio in ceiling and dash
Wants:
Air Conditioning
OEM Bed Rails (On Christmas List, can anyone help Santa out?)
Music
Tonneau cover, maybe
Bed Side, maybe
Remove Front Grill Guard
Remove Running Boards
Remove Rear Mud Flips
Goals:
Going - Daily Driver;
Pass Safety inspection and emissions test for Utah
Title and registration in Utah
Decent Gas Mileage
Towing - Maybe;
This pickup has towed a 1969 31’ foot Airstream. I have a 1959 24’ Airstream, 3350 pounds.
Showing - Maybe;
All depends on how it is restored.
Thanks in Advance, Rod
Photos: https://www.ford-trucks.com/forums/a...p?albumid=9865
GVWR: 5450 pounds
Wheel Base: 133’
1 = USA
D = 5,001-6,000 lbs
F = F-series
15 = F150
B = 1981 model year
Explorer Package A:
7: Chrome Grille
Power Steering
Power Brakes
Aux. Fuel Tank
Sliding rear Window
Under dash lights
Cargo Light
Electric Brakes
Work Done On Pickup
2008 - New Clutch
2008 - New Tires
2008 - New Starter
Needs / Repairs:
Install Tachometer
Wants:
Air Conditioning
Music
Bed Side, maybe
Goals:
Decent Gas Mileage
Towing - Maybe;
Showing - Maybe;
Welcome to the site!
That color sounds alot like the one on my truck.
Sounds like you know her from top to bottom.
For the map light,check the wiring.The previous owner of my truck was nice enough to cut my wires for me.This might not be your problem,but it's easy to check.As for that tach,make sure you have the tach printed circuit from a 1981-1986 Truck or Bronco.
It's been awhile since I did that fix and looked at the diagram,but I think they were on different circuits.
I completely missed this.
10w40 should do you good.That's what most people seem to run,and that's what i've got in mine.As far as oil Brands,it's a matter of preference,but Shell Rotella seems to get a good rep.As for filters,your best bet is Wix or Motorcraft.I haven't heard anything bad about them.Stay away from Fram,they're one of the worst filters out there.
Wow you do have alot of information about your truck. Where did you find it all?
I thought my under hood light was added later but maybe it was factory, same with the bed rails. I think my tires are even original, I found a pamphlet with the paperwork for general tires and that's what tires are on it.
I just edited my post.If it looks like it's been wired in poorly,than it was probably added after the fact.Sadly,it's a plug and play option,but I guess the Previous owner didn't know that.
