Ignition Lock Cylinder removal with NO key. - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 08-11-2010, 04:43 PM
60RatRod's Avatar
60RatRod 60RatRod is offline
60RatRod has a good reputation on FTE.60RatRod has a good reputation on FTE.60RatRod has a good reputation on FTE.
So I have a replacement steering column for my truck and need to swap out lock cylinders. My question is; since there is NO key, is there any way to avoid drilling out retaining pin. If I did drill it out am I entirley screwd'? Any ideas or sugestions?
Old 08-11-2010, 06:19 PM
Want-A-Be 7.3's Avatar
Want-A-Be 7.3 Want-A-Be 7.3 is offline
Want-A-Be 7.3 is starting off with a positive reputation.
I haven't tried a ignition switch befor but you might try to pick it. ??? I would sure try that first befor destroying my column.
Old 08-11-2010, 06:41 PM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
You might find a wrecker driver or automotive locksmith with a set of "tryout" or "jiggler" keys for Ford 8-pin.
Pop
Old 08-11-2010, 06:46 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Drive your truck and bring the new steering column to the nearest large town police department. See if one of them will tell you or volunteer to do it while you're not looking. Those guys probably see enough cylinders busted by thieves they can tell you how to do it for cheap.
Old 08-11-2010, 06:52 PM
jc8825's Avatar
jc8825 jc8825 is offline
jc8825 is gaining momentum as a positive member of FTE.jc8825 is gaining momentum as a positive member of FTE.
Get the VIN number from the part truck you got the column from and the dealer should be able to cut a key for it.
Old 08-11-2010, 07:12 PM
60RatRod's Avatar
Quote:
I did geab the V.I.N. when I pulled the column. I did'nt know that the stearlership would do that without out valid proof of ownership i.e. vehicle registration or proof of insurance.
BTW LMAO Chris, your probablly right though LOL
Guess I will call Ford and see if they will cut a key bt V.I.N. I'll let you guys know how that goes.
Thanks Dan
Called Ford dealer; they said they only keep V.I.N. record (for keys) 10 years back. the truck is an 03/2000 and no key cut by vin. Re cylinder and keying would cost $180.00
Old 08-11-2010, 09:42 PM
jc8825's Avatar
Quote:
That is ridiculous. I had keys made for a 1989 RX7 and an 1986 RX7 at the Mazda dealer and I had a key made for an 86 CRX at the Honda dealer once. That seems ridiculous that Ford only "keeps records for 10 years". VINs don't change so once a record, always a record. Stupid.
Old 08-11-2010, 11:13 PM
takotruckin takotruckin is offline
takotruckin has a good reputation on FTE.takotruckin has a good reputation on FTE.
Here is what Ford says to do
I hope you can read it well enough. I don't really know why it says to remove the wheel. I've done it before with it on.
Old 08-12-2010, 12:26 AM
60RatRod's Avatar
Thanks Takotruckin, I ended up drilling out the tumblers, removed old cylinder and No damage to my column, ready to install my ignition
Old 08-12-2010, 01:46 AM
Thanks for closing this out with results!
Pop
Old 08-12-2010, 03:52 PM
60RatRod's Avatar
Quote:
Pop
Welcome Pops,
I figure the next guy in this situation can always refer to this thread and see what option worked best for me. After all isn't that why we are all really here, to help one another.
Dan
Old 02-10-2011, 01:27 AM
stangclassic66 stangclassic66 is offline
stangclassic66 is starting off with a positive reputation.
Thanks for the information and close-out. This will help me tomorrow when I replace the cylinder.
Old 11-20-2011, 11:40 AM
papashowcow papashowcow is offline
papashowcow is starting off with a positive reputation.
What Is the Purple and Black Wire in Photo 1, I removed my key cylinder and found that the black plastic was broke and a flat piece was laying in the cylinder well. My Stater is engaging off and on while my truck is running and my truck will start when turning the key cylinder to the run position without turning all the way to the start position and releasing
Old 11-20-2011, 11:49 AM
Ponyboychris's Avatar
Ponyboychris Ponyboychris is offline
Hit it!
Ponyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud of
Thanks Dan as well. Since most of us are reaching the 10 year statute of limitations with our trucks, this is good to know.
Old 08-08-2016, 04:00 PM
dicktar dicktar is offline
dicktar is starting off with a positive reputation.
i followed the insructions to the t, used an 1/8" drill bit to drill up the access hole and a 3/8 bit thru the center of the key slot, at first about 1 3/4" then almost 2", i can see a screw driver when i slide it up the access hole inside the cylinder, the cylinder won't move to the run position, even using vise grips to apply force,the switch won't slide out,WHAT CAN I DO, thanks to any one, dick b
My F-2000 to F-2015 Build vortec 1 1999 to 2016 Super Duty 333 02-19-2017 10:43 PM
86 F150 2WD Tires Lightning23 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 35 01-26-2017 02:55 PM
Introduction and Clutch Question On 1946 2 Ton Craig46 1947 and Older Ford Trucks 35 12-19-2015 03:16 PM
Vibration only when towing -dave- 2017 Super Duty 0 12-01-2015 09:27 AM
This weekend's project, turbo mods off to a good start 60RatRod 1999 - 2003 7.3L Power Stroke Diesel 85 07-04-2010 07:19 PM
Tags
00, 1972, cylinder, evo, f350, find, ford, ignition, key, lock, number, older, removal, replace, switch, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
