460 water pump - Ford Truck Enthusiasts Forums
460 water pump
Old 08-11-2010, 02:56 PM
blakebuckley blakebuckley is offline
blakebuckley is starting off with a positive reputation.
460 water pump
ok so i just got a 76 f100 with a 460 and it needs a few little things done to it. right now im trying to figure out the water pump problem. its not pumping very much at all, compared to what i would imagine it should. its not leaking anywhere so i didnt think it was bad. there are two lines going to the head from the pump. one has a bad kink in it but how the line is routed it would have to be like 2 feet long instead of 6 inches to avoid this. what are these lines?
thanks<!-- google_ad_section_end -->
Old 08-12-2010, 11:49 AM
Victor L's Avatar
Victor L Victor L is offline
Victor L is starting off with a positive reputation.
My 460 does not have that short line going to the head like yours, but i would find a preformed line with a bend at the auto parts, and see if that fixes your problem. You may need to take out the thermostat, and leave it out until you solve the problem. Pay attention when it comes out, make sure it was not installed backwards.
See if you can find a radiator shop that will reverse flush your cooling system. Hopefully you can get rid of any blockage, and avoid digging into your engine.
Old 08-15-2010, 12:56 PM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
Is it running hot or something ?
Old 08-19-2010, 05:12 PM
ya it over heats quick. like after 3 minutes of driving
Old 08-19-2010, 09:25 PM
Victor L's Avatar
Do you mean that it is ready to boil over after starting the engine cold?
Old 08-20-2010, 07:07 AM
ArdWrknTrk ArdWrknTrk is online now
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
Quote:
Originally Posted by blakebuckley View Post
...there are two lines going to the head from the pump. one has a bad kink in it but how the line is routed it would have to be like 2 feet long instead of 6 inches to avoid this. what are these lines?
There should only be a very short bypass hose coming from the center of the intake manifold to the back of the pump and a line coming from the heater core to the boss near the passenger side head.
...And of course the lower radiator hose (intake)
<a href="http://www.flickr.com/photos/24183730@N03/2341395806/" title="IMG_1899 by Jim_Urrata, on Flickr"><img src="http://farm4.static.flickr.com/3149/2341395806_7dcc45b8f6.jpg" width="375" height="500" alt="IMG_1899" /></a>
As you can see the upper radiator hose comes from the thermostat housing and the output to the heater core just in front of it.
Maybe the heater core is bypassed and that is the hose you say is kinked?
I would remove the thermostat from it's housing and boil it in a pot of water to be sure it is opening. (inexpensive enough to just replace)
Worst case scenario water pump change. Need advice. thunderbolt61 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 4 09-28-2014 04:53 PM
Water pump replacement on a '92 460 - a few questions SoCalAngler Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 0 08-10-2014 06:23 PM
1979 f-250 loosing water fast projectdagger 1973 - 1979 F-100 & Larger F-Series Trucks 2 12-05-2013 12:50 AM
Boss 429? Jam21 1973 - 1979 F-100 & Larger F-Series Trucks 23 01-19-2013 07:23 PM
1987 F250 460 Heater hose 2007F150FX4 1987 - 1996 F150 & Larger F-Series Trucks 9 07-07-2010 09:25 PM
Tags
460, bad, bypass, changing, ford, hose, pump, removing, replacing, signs, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
