Read First: 6.7L Tech Folder - Ford Truck Enthusiasts Forums
Closed Thread
Old 08-11-2010, 02:00 PM
Maxium4x4's Avatar
Maxium4x4 Maxium4x4 is offline
Maxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputation
6.7L POWER STROKE DIESEL OVERVIEW 6.7 Diesel pdf
6.7L Engine Design Information
Thanks, pbruckne
6.7L Oil Change How-To-Video
Thanks, EpicCowlick
6.7L Oil Change Interval Information
Thanks, pbruckne
Transmission Shift "Flare" View Single post
Thanks, Big-Sarge
Must carry in your truck - exhaust temp sensor failure View Single post
Thanks, smoky_diesel
Exhaust smell in cab of truck during Regen Click Here
Turboflutter/TruckShutters (DURING REGEN) Click Here
Turboflutter/TruckShutters (NOT DURING REGEN) Click Here
Service Action 10B17 Click Here
Thanks, Cheezit
Service Action 10B17 Released View Single post
Thanks, EricInWI
TSB 10-23-9 Click Here
Thanks, ruschejj and PowerstrokeHD
TSB 11-04-21, corrects CEL and erratic shifting Click Here
Repeat P0164A NOx sensor calibration problem Click Here
TSB 11-10-10, DEF contamination and internal injector short Click Here
TSB 11-07-10 View single post, Reverse hesitation.
Thanks, Bob (ftr2599)
TSB 16-0087 Rear End Bounce or Hop
Diesel Technician Society About DTS
Coffee Table Book Tech Publications Download for the 6.7 Turbo Diesel 20Mb
SEIC High Idle Instructions
Thanks, mvedepo
2012+ Upfitter switches and how to access them. View thread
Thanks, 99150
Aux Upfitter Switch-Wires Discussion and PDF Information
5th Wheel Prep Option Questions and answers
Thanks, Tomahawk
Door Chime Door Chime Disable
Thanks, Tomahawk
2011 6.7L DTC (Diagnostic Trouble Code) List Click Here
Thanks, PowerStrokeHD
Sept 2,2010 General Information Changes/Updates
Thanks PowerStrokeHD
Driver Front Door Interior Wind Noise Tips & Tricks
Video Instructions Click Here
Thanks, EpicCowlick
How-To-Video's
Removing Front Grille
Adjusting Headlights
Husky Mud Flaps Installation
Titan Tank Installation
B&W Companion Hitch Installation
Airbags Installation
Fuel Filter Change
Fuel Filter Inspection
Dual Steering Stabilizer and Shock Installation.
Thanks, EpicCowlick
Rancho My Ride Installation
Thanks, KC8QVO
Bilstein 5100 Installation Thread with Video
Thanks Big-Sarge
2011-2014 DEF Tank removal
Thanks, firebus
Instrument Cluster Engineering Test Mode
Thanks, rdenis
DEF (diesel exhaust fluid) and SCR Summary
Thanks, pbruckne
Damage caused by DEF in the fuel tank. DON'T do it!
Thanks, EpicCowlick
Check Coolant Additive Information including test strip part number.
Motorcraft Oil Filter Comparison
Thanks, pbruckne
Diesel Fuel Quality and Warranty Information
Thanks, pbruckne
Chat with engineers Chris Brewer(SD chief engineer), Adam Gryglak(6.7L Powerstroke) and Mike Harrison(6.2L gas) HERE.
Do it yourself radiator petcock wrench
Thanks to rdenis
Diesel smell in cabin (loose exhaust)
6.7L Engine Coolant Compatibility Information
6.7l OBD operation
Thanks to Thenewboss
Adding RapidHeat Supplemental Heater
Thanks to thejean
Old 10-10-2013, 01:57 PM
BigF350 BigF350 is offline
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
Acronym definitions, intro to the 6.7 engine and commonly asked questions.
The 6.7l was a new clean sheet engine design introduced with the 2011 Ford Super Duty. The engine was designed by Ford, and is built by Ford in Mexico.
The 2011-2014 6.7 engines are available in 2 configurations, the version available in the F-250, F-350 and F-450 pickup (400hp, 800lbft), and the version available in the F-350, F-450 and F-550 cab chassis (300hp, 660lbft). The basic engine is the same between these 2 version, but there are some key differences (turbocharger, engine calibration etc.)
Its basic layout of the engine is a V8 diesel with direct common rail injection. The flow of the heads is opposite of most production engines (exhaust ports are in the valley of the engine).
The 2011-2014 engines have a conventional Garrett GT32 turbocharger, with the pickup trucks having a 2 stage compressor wheel. The 2015+ engines will have a GT37 turbocharger.
The engine block is made from Composite Graphite Iron (CGI), a high strength steel, with Aluminum heads.
Other unique features are the 2 separate cooling systems a high temp one (194 degrees to cool the engine) and a low temp one (122 degrees to cool the air-to-water intercooler, transmission fluid, fuel cooler, and EGR system).
The 6.7l diesel was the first diesel engine in a Ford pickup to be fitted with Urea injection, and has a quite complex emissions system.
Common Acronyms/names.
6R140 - the name for the transmission fitted to all 2011+ (diesel or 6.2 gas) trucks. It stands for 6 speed and that it will accept 1,400 lb.ft of input torque.
DEF - Diesel Exhaust Fluid. Also potentially called SCR (Selective Catalytic Reduction) or Urea Injection. This system is new on the 6.7l trucks, and it is a fluid that gets injected into the exhaust of the truck to reduce its NOx output. The filling system for this is located next to the diesel tank filler, and it will need to be topped up every ~5,000 miles or so. Almost all modern generation diesels use a system similar to this.
DPF - Diesel Particulate Filter. This is a system fitted to the exhaust of all 2008+ PSD's that "traps" particulates and soot. Periodically this filter needs to have its soot contents disposed of - something the engine does automatically by "regen'ing". The 6.7l does this less frequently than the previous 6.4l PSD due to the addition of the DEF system.
EGR - Exhaust Gas Recirculation. This system selectively pulls some exhaust gas through a cooler and into the intake of the engine.
Emissions system - As mentioned the emissions system on a 6.7l is complex, and involves the EGR, a Catalytic Converter, DEF and DPF.
Here is a diagram of the post turbo exhaust system.
"Flash" - This is what updating the engine or transmission calibration is called.
PSD - Power Stroke Diesel. What Ford has called the diesel engines it has fitted to its pickup trucks since 1994.5. 7.3l PSD 94.5-03, 6.0l PSD 03-07, 6.4 PSD 08-10, 6.7 PSD 11-?
Regen - this is the process the engine goes through to eliminate the soot in the DPF. There are 2 ways this can happen. Active regen - a message comes up on the info screen briefly when the truck is undergoing an Active regen, and you will notice the instantaneous milage drop. The truck essentially injects a lot more fuel than normal into the left hand bank (drivers side) to really heat up the exhaust system to burn the soot out. Lots of stop/start driving with the engine not getting hot will cause this to occur more frequently. Passive regen, when the truck engine gets really hot (usually only while towing a large load), the DPF will begin burning soot off of its own accord. This process doesn't involve injecting additional fuel and you will not receive a message on the info screen when this is occurring, nor should you notice a drop in milage.
Closed Thread
Tech/mod info links strokin'_tatsch 1994.5 - 1997 7.3L Power Stroke Diesel 74 01-12-2017 12:46 PM
MASTER COPY old Excursion Forum Tech Folder Stewart_H Excursion - King of SUVs 0 02-02-2012 12:49 AM
1968-Present E-series Tech Folder Tom 1968-2013 Full Size Vans 0 01-23-2012 10:03 PM
6.4L Diesel: 6.4 Tech Folder kw5413 6.4L Power Stroke Diesel 1 07-06-2009 08:26 PM
6.0L Diesel: ..................Tech Folder.............. IB Tim 6.0L Power Stroke Diesel 1 07-04-2006 01:01 AM
Tags
10239, 1986, 350, 67, 67l, diesel, folder, ford, international, pdf, powerstroke, question, tech, tsb, tsb110421
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
