Axle ratio from VIN? - Ford Truck Enthusiasts Forums
Old 08-10-2010, 08:44 PM
I.B. Washincars's Avatar
I.B. Washincars I.B. Washincars is offline
I.B. Washincars is gaining momentum as a positive member of FTE.
I am contemplating buying another Sport-Trac. It is an '04, VIN 1FMDU77K34VAxxxxx. The one I have now has a 4.10 ratio and doesn't get the mileage that I would like. Can you get the axle ratio from the VIN I posted? I would rather not buy another one with the low gears.
Old 08-11-2010, 06:31 AM
ncranchero's Avatar
ncranchero ncranchero is offline
ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.
Does it not have a Vehicle Certification Label on the door?
Axle codes are:
42 4.10 ratio, non-limited slip
46 3.73 ratio, non-limited slip
D2 4.10 ratio, limited slip
D4 3.73 ratio, limited slip
Did you try taller tires to raise the final drive ratio? I think 265/75R16's will fit without much of an issue. Higher gearing does not always mean better mileage either..........
I have 3.73's and wish I had the 4.10's.
Old 08-11-2010, 07:20 AM
It's about 3 hrs. from me and I haven't gone and looked at it yet. I'm not terribly worried about the mileage of the one I have now and have done nothing in an attempt to improve the it. My daughter just totaled her car and I was contemplating letting her have it and buy a newer one for my wife. I was hoping to get one with the OD transmission and higher axle ratio and hopefully higher MPG.
I double checked the VIN and noticed that I had it wrong. The correct one is 1FMDU77K34UA28844.
Old 08-17-2010, 01:40 AM
snakeside snakeside is offline
snakeside is starting off with a positive reputation.
Call any ford dealer with the vin and they can tell you, just ask for parts, and tell them you need a ring and pinion for that vin and ask what ratio it is.
Old 08-17-2010, 06:32 AM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
The parts department will tell you to go read the axle code on the VC label and call back.
VIN Decode/ Number Dummy HELP! thorswhisper 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 05-04-2015 12:02 AM
VIN number decode for Gear ratio???? 1982_f150 1994.5 - 1997 7.3L Power Stroke Diesel 9 09-16-2014 10:43 PM
Rear axle ratio change? lwclark 1957 - 1960 F100 & Larger F-Series Trucks 8 05-01-2012 06:28 AM
How can I find axle ratio on '02 EX harris2108 Modular V10 (6.8l) 11 11-26-2006 09:20 AM
Rear axle ratio rowdy200 1997 - 2003 F150 3 06-18-2003 09:55 PM
Tags
373, axel, axle, cars, code, codes, decoder, donor, duty, f250, ford, limited, ratio, ration, slip, super, truck, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
