I need help indentifying this dual quad intake
#31
Charlie, they are air flow operated, not vacuum and you can still get way too much air in any of the mechanical secondary carburetors. When Ford used Carter carbs on their engines, the first ones had vacuum secondaries, later ones like the 63-65 Lincoln 430 had the standard Carter mechanical secondaries. Even those big torque monsters could bog when stomped from idle at a light, but usually ended up lighting the rear tires.
A well calibrated vacuum secondary system like the 390cfm Holleys you pictured, works very well, my own setup used the synchronising hose between the carbs so all 4 secondary barrels opened at once.
#35
#36
#37
Teapot 2x4's
Guys,
A friend of mine in Norther WI is a big E-code enthusiast. He's got a bunch of them and can help you out with picking out a good combination to make it run. He's also got a real good source for rebuilding the t-pots as well.
Let me know if you want to talk to him and I'll get you his contact info.
Nick
Nick
Lee in Neenah, WI
#39
Contact info
Thanks!
#40
Lee Dombrowicki,
How we restore your carburetor and current pricing. is who (northern WI) Randy recommends as of now.
His guy who I referred people to back in the 2010 dated posts had a brain aneurism so he's not using him anymore. My buddy has a set of R1434 teapots at another new guy with the hopes that they turn out great.
Nick in WI
Nick in WI
JesterPgh
27
10-20-2020 07:23 PM
boggin79ford
83
09-09-2016 06:29 PM
KaiserM715
Ford Truck Parts for Sale
10-16-2015 08:36 AM
Resurrected 56 F100
09-03-2015 04:19 PM
