Pro street truck - Ford Truck Enthusiasts Forums
Pro street truck
Old 08-10-2010, 07:35 PM
DaytonaTunnel's Avatar
DaytonaTunnel DaytonaTunnel is offline
DaytonaTunnel is starting off with a positive reputation.
Pro street truck
Anyone here know of a Pro Street dentside ? I just picked up a '78 2wd shorty. I've always dreamed of building a Pre Street 78-79, and now it can happen (if I ever finish my 79 Crew!). I'd love to see some pic's if anyone's got any. Thanks as always !!!
Old 08-10-2010, 09:16 PM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK Pro-Street/StateTK is offline
Pro-Street/StateTK is gaining momentum as a positive member of FTE.
Daytona Tunnel
check out my gallery ,I have Pro-Street'ed a 77 F-100 & a 65 F-100 , I also have a article here (FTE)
Have you thought out how you are going to Pro-Street your truck ,4 /Link, ladder bars , or moving the leafs inside /or under the frame?
Wally Womack
Last edited by Pro-Street/StateTK; 08-10-2010 at 09:21 PM. Reason: watching my Ps and Qs
Old 08-12-2010, 02:59 PM
THANKS for the response !! I like your truck a lot, nice build !!! I have a few questions maybe you can answer ? I'd like the truck to sit low to the ground AND run steam rollers out back. Do you know if this is possible ? Second, how did you lower the front end ? Kit or home job. Thanks for any help
Old 08-12-2010, 03:34 PM
Rubenk's Avatar
Rubenk Rubenk is offline
Rubenk is starting off with a positive reputation.
I've always liked the look of this truck...
YouTube - Black Widow 429
good luck with your build!
Old 08-12-2010, 04:10 PM
73FordF100's Avatar
73FordF100 73FordF100 is offline
73FordF100 is starting off with a positive reputation.
Here's two. Unfortunately I don't know any specs on them.
Old 08-12-2010, 10:09 PM
That is almost EXACTLY what I've been looking for !!! That is freakin BADASS looking !!!
Old 08-13-2010, 10:47 PM
Quote:
Daytona Tunnel
Thanks for the nice words, I have not lower the front of the two Pro-Street trucks , I have pulled a
trailor with the 77 ,and also hauled a 351w, c4 trans, and a rental cherry picker ,in the tubbed bed ,
all in one load !
Keep us posted on the build, take lots of pics ,and maybe start a build thread !
Wally Womack
Old 08-14-2010, 01:34 AM
Frank-N-Ford Frank-N-Ford is offline
Frank-N-Ford is starting off with a positive reputation.
The way that we are lowering the front of mine is by having a frame shop bend the I-beams. You must also run shorter springs when you do this. Hope this helps.
As far as dropping the rear end down the best way that I have seen is to C notch the rear frame above the rear end.
Also anyone know where I can find a hood or a scoop like the one on the blue truck?
Thanks,
Frank-N-Ford
Old 08-14-2010, 07:37 AM
73FOMO's Avatar
73FOMO 73FOMO is offline
73FOMO is gaining momentum as a positive member of FTE.
You can get that full fiberglass cabs, doors, fenders, beds, front clips at usbodysource.com, and at up22.com. That hood looks to be full fiberglass and not just a scoop, and looks like a model fd-384 4" rise at up22.com. It weighs only 60#'s and cost $400. I'm sure that would save about 100 + pounds on the front end of this truck....a great start. Now if you could just stuff a 2011 5.4 aluminum block GT500 motor in there....102 + lighter than iron 5.4, 550hp, 510 tq, with decent mpg. That would make a great start to a killer pro/street truck. Speaking of that, does anyone know of anyone who has ever pulled off a 5.4 swap into one of these trucks?
new to the site Jchet729 New Member Introductions 3 07-11-2014 01:37 PM
Innovative Diesel Tuning Dlinzy 6.0L Power Stroke Diesel 11 03-08-2012 06:55 PM
SCT Tuner X3 Pre-Loaded Tunes timbo126 6.0L Power Stroke Diesel 9 08-04-2011 04:02 PM
first time 351W build luckydoggy Performance & General Engine Building 9 09-25-2008 04:55 PM
Fiberglass Tilt Frontend for 1966 F-100 jagnut55 1961 - 1966 F-100 & Larger F-Series Trucks 2 05-20-2002 03:33 PM
Tags
1973, 19801986, 1995, building, f100, f150, f250, ford, forums, pro, prostreet, sale, street, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
