I have a 63 f100 and I am wanting to swap out the tranny.....right now its a 3 on the tree. I'm looking for any trannys that will bolt up to my 223 other than the 3 speed
A T98 four speed will bolt up but it has to be 64 and older. Bell housing mounting pattern and depth changed for 65 and carried all the way to 96 with some minor input shaft base diameter changes.
You can mount a T45 using one of John Mummerts bell housings and a mid 80s trans from a 6 cyl mustang..
I have swapped three to four the pattern is the same. I did not know there was two separate bells. for manual transmissions. See even i can learn something new.
