Go Back   Ford Truck Enthusiasts Forums > Bronco > 1978 - 1996 Big Bronco
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
  #1 (permalink)
Old 08-10-2010, 03:27 PM
jfritts jfritts is offline
1990 Ford Bronco
jfritts is starting off with a positive reputation.
90 Bronco 4BT Diesel Build
I got a 1990 Eddie Bauer bronco with 240k miles on her. Had a 351w that had a few mods but I was getting 10mpg on a good day and just wasnt happy with it. Decided it was time for a diesel and ZF-5 swap to beef up my drivetrain and get some better mpgs out of her.
What I started with:
Click the image to open in full size.
Bought me a 86 Chevy P-30 step van with a 4bta. Couldnt find a buyer for the van so it got the axe and the rest got sold for parts.
Scrapping:
Overall about 1800lbs of aluminum and 2000lbs of steel.
What 1200lbs of steel looks like in a bronco:
  #2 (permalink)
Old 08-10-2010, 03:32 PM
1990 Ford Bronco
Pulling the 4bta:
Safe in my very crowded garage:
Found a ZF-5 S-42 from a member on 4btswaps.com.
Parts hauling in my wifes car
Got a stock step van 4bt to small block ford adapter setup. Included adapter plate, flywheel, starter, clutch, pressure plate, and master cylinder. I ended up getting a new clutch, pressure plate, and master cylinder just to be safe tho.
Starter had been ground a bit for clearance i guess
  #3 (permalink)
Old 08-10-2010, 03:37 PM
1990 Ford Bronco
At the time I thought I could do the swap in a week sooo I took a week off from work. My brother and I got started by tearing my bronco apart.
Engine out:
Transmission and tcase pulled. Goodbye E4OD!
My workspace, apartment complex parking lot. Definitely not the recommended spot for a engine swap and we will touch on that more later.
Empty space
Cleaned up and repainted
Had the drivetrain out in one day. Thought I was making good progress but I only had downhill to go.
  #4 (permalink)
Old 08-10-2010, 03:44 PM
1990 Ford Bronco
Pulled the engine outside to degrease it and put on some fresh Cummins beige paint.
Painted the exhaust manifold as well
Found out the ZF-5 needs a different crossmember so it was back to the junkyard.
ZF-5 in her new home, held in by only a ratchet strap and resting the crossmember on the frame.
Tuesday morning I woke up to no bronco. Apartment complex cracked down on my work and had her towed. Lucked out because my transmission didnt fall out while being towed.
Picking it up from the impound lot, This is also the fastest way to get more lift
Had it towed to the hobby shop on base. Probably where I should have started in the first place.
  #5 (permalink)
Old 08-10-2010, 03:53 PM
1990 Ford Bronco
Started mounting the flywheel and clutch up to the engine. Tip for other people, The chevy flexplate has a adapter on the back of the 4bt which just comes off with a few taps of a hammer. No reason to start freaking out because your flywheel doesnt fit
Testing the fit for the 4bt and mocking up motor mounts. Ended up using the stock mounts that bolt to the engine and then some 300 I6 mounts. Had to get a bushing from Autozone and then some grade 8 bolts.
Mated up to the transmission
Hood clearance is a little close
All bolted in. It was a PITA getting it lined up and both sides bolted down
tons of room in front. Plenty of space for a very very large intercooler
Tried using the hydroboost setup from the chevy stepvan but it was nothing but hassles.
Ended up pulling a new hydroboost setup from a later 90s early 2000s model truck and used that.
The failboost
All bolted up:
  #6 (permalink)
Old 08-10-2010, 03:57 PM
1990 Ford Bronco
For the fuel system I pulled out the intake pump and pulled all the stock EFI lines. Then I just ran a pickup line into the tank and new lines all the way up to the engine.
Finally got a third pedal in my rig!!
Engine must have moved the ZF-5 back some because I was able to retain my stock driveshaft. I havent tried to put the front one back in yet but time will tell.
  #7 (permalink)
Old 08-10-2010, 04:00 PM
1990 Ford Bronco
Few random pics:
Order some gauges from summit racing. Boost, oil pressure, and exhaust gas temp. Along with a A-pillar gauge pod.
  #8 (permalink)
Old 08-10-2010, 04:03 PM
1990 Ford Bronco
Picked up a stock dodge intercooler. For reference it is leaning against a 38 inch tire.
Future mods to the engine include: 3200rpm spring, dennyt fuel pin, intercooler, turbo from a 6bt.
I got it all back together and driveable in 25 days. Runs pretty good and has plenty of power once the turbo spools up. All i have left is cleaning up my wiring mess, hooking up my a/c and heater.
  #9 (permalink)
Old 08-10-2010, 09:38 PM
helirich helirich is offline
Garage is empty, add now
helirich is starting off with a positive reputation.
So your running it completly stock and it is comparable to the 351? Or did you allready do the mods? What did you do for a A/C compressor mount?
__________________
90' Bronco, 351, MSD Ign., SS 3" exhaust,
38" x 15.50 R15 Dirt Grips, 14" x 15" Alcoa wheels
6" lift w/ cutout flares, 40 gal. fuel tank
F diff - lockright locker, 4.88's
R diff - Powertrax locker, 4.88's
Cast diff cover w/ carrier braces
Rear full float axles, truss, Above spring traction bars
  #10 (permalink)
Old 08-10-2010, 09:44 PM
1990 Ford Bronco
Yea its stock for right now. Id say off the line it is slower but once it gets some boost built up then its about the same. I also switched transmissions so my gear ratios are different than before. I am sure that after a few mods (fuel pin, rpm spring, and intercooler) it will be faster. And with a new turbo it will be a lot better. I havent mounted my A/C yet. It is just laying in the engine bay.
  #11 (permalink)
Old 08-12-2010, 07:57 PM
1990 Ford Bronco
Boost and Pyrometer in the A-pillar
Oil Pressure where the overdrive switch use to be
Also finished mounting up my temporary exhaust until the new turbo gets installed. Runs out right before the passenger rear tire.
  #12 (permalink)
Old 08-13-2010, 11:37 AM
American Thunder's Avatar
American Thunder American Thunder is offline
1978 Ford Bronco
My Garage
American Thunder is starting off with a positive reputation.
Looks good so far!
__________________
1978 Bronco - 12V Cummins power, pump mods, Dynamic Racing Transmissions C6 automatic, Billet 1200 rpm converter, Destroked adapter and billet flexplate, NP205 t-case, 9" lift, 35s, 3.50 gears, upgraded brakes and braided hoses, 4" exhaust - no muffler. GOT TORQUE?
  #13 (permalink)
Old 08-15-2010, 09:09 AM
Where did you put the sensors for pyro and boist? As I understand it, you only have the fuel pump on the engine? (none in the tank or inline)
__________________
  #14 (permalink)
Old 08-15-2010, 01:01 PM
1990 Ford Bronco
For the boost you just pull one of the plugs below the intake. I will grab a picture today. I havent mounted the sensor for the pyro yet but it will go about 5 inches behind the turbo.
Right just the pump on the engine
  #15 (permalink)
Old 08-15-2010, 02:25 PM
BigPigDaddy's Avatar
BigPigDaddy BigPigDaddy is offline
2000 Ford F-250
My Garage
BigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to behold
You sure made that look easy!
What kind of RPM are you running at highway speed? Any plans to change gearing?
__________________
- Jeff
2000 F250 V10 5-SPD 4X4 Crew w/ 5-Star SCT X3
1949 F1 - (WORK IN PROGRESS THREAD)
Tags
1996, 4bt, bronco, bt, c6, diesel, f250, flywheel, ford, ii, p30, step, swap, van, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
