1952 Ford Truck Transmission
Here are your Transmission Specifications:
Part Numbers from the Chassis Parts Catalogue for the 5 Spd Overdrive (standard on the F7, Optional on the F8) is: 7EQ 7004. ($ Fifth Speed is overdrive).
P/N for the 5 spd Direct (standard on the F8, Optional on the F7) is: 7EQH 7004 (*5th speed is direct drive).
In typical Ford Fashion there is no mention of an outside manufacturer or their model number in the Shop Manual, or the Parts Catalogues.
I'll look around and see if I can find something. In the mean time I'm sure one of the other folks will know.
Yeah, if I can sort out the scanning feature of the new printer/scanner. I tried on something else this afternoon and gave up. If you want the book set it's the reprint two volume version of the '48 to '56 Chassis Manual that you can buy from just about all the vendors.
OK, glad you found it. Stu
Darndest things what you find sometimes that you didn't know you had. Seems I find new oddball wheel listings every time I go digging for somebody. For instance, I just found a 20" Budd with 6 x 7.25 that I never knew existed. The only thing I have on CD is a '49 Hildy's that I got from Bob. Otherwise I sit here surrounded by books.
The printer/scanner is a wireless network job. An HP Photosmart Premium that right now is thinking it's smarter than I am. Stu
Yep same printer/scanner I have. You have to be sure to download the "HP Solution Center" AND turn off your router firewall during the start up "initialization" (where your computer and printer talk to each other for the first time). Other wise the competer software doesn't finish loading. Not sure if you are past that point yet, but it took me 3 days on the phone to Pakistan with HP to finally get someone to tell me that the router had a firewall and it needed to be disabled (then three more with the router Co. to finally convince Remadi that I really needed to turn off my router firewall and have him tell me how to do that!).
Have fun!
leonharu
01-11-2014 08:44 PM
Rob C
12-04-2013 06:37 PM
rosthaufen
15
02-25-2012 10:01 AM
1954-5EFFIE
02-06-2011 07:19 PM
