no fuel from injectors 01 f150 - Ford Truck Enthusiasts Forums
Old 08-10-2010, 08:51 AM
bigmac1980 bigmac1980 is offline
bigmac1980 is starting off with a positive reputation.
SI've got a 01 f150 yesterday stopped running (like it ran out of gas). Has half a tank. Fuel pressure at rails good but truck will not turn over. Fuel pump and filter less than year old. Anyone else having any problems like this
Old 08-10-2010, 03:50 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
If the truck will not turn over, the injectors will not fire. It has to see inputs from the crank and cam sensors to know when to fire them.
stock cams 97 vs 01 IDIoit 1999 - 2003 7.3L Power Stroke Diesel 4 12-23-2016 06:21 PM
4.2 F150 fuel injectors at .01 ohms Ron032 Fuel Injection, Carburetion & Fuel System 0 11-07-2016 11:07 AM
fuel gauge problem after fuel injection swap weswes01 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 05-23-2016 08:06 AM
01 4.6 swap to 01 4.6 P71 motor edhaney01f150 Engine Swaps 3 02-27-2007 09:25 AM
Fuel Schrader Valve Location 01stroker 1999 - 2003 7.3L Power Stroke Diesel 11 07-27-2004 08:22 AM
Tags
01, 01f150, f150, filter, fuel, injector, injectors, preshure, tnjectors, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
