A/C refrigerant capacities - 87 F150
Old 08-10-2010, 07:40 AM
rickthefix's Avatar
rickthefix
rickthefix is offline
Hey gang, been a while since I posted
I'm going to revive the A/C system in my 87 F150 4x4 5.0L, the evaporator was removed & been down for many years. Any one know the refrigerant and oil capacities?
Also, as most of you know, when trying to remove the accumultor from the evaporator, the accum aluminm threads galled the evap steel threads. Anyone know a good/easy way to remove the aluminum from the steel nut?
TIA,
rickthefix
Old 08-10-2010, 12:23 PM
Old93junk's Avatar
Old93junk
Old93junk is offline
2.8lbs of R-12........unless you have switched to r-134.
Old 08-10-2010, 02:06 PM
rickthefix's Avatar
rickthefix
I will be switching over to R134-A, so it should take 85% of the original amount. But I also need the amounts of PAG oil to put into each component if you know that.
TIA,
Rick
Old 08-12-2010, 10:57 AM
john griffin's Avatar
john griffin
john griffin is offline
The sticker on mine says 3 lb, 4oz, and I have heard you charge 80%, witch is 41.6 oz, just done mine and that amount worked good, I also used a orange orfice tube, it was for a E-150 same yr.
Old 08-12-2010, 11:55 AM
stick shifty's Avatar
stick shifty
stick shifty is offline
134a
did my 89 f250 last week and i stopped at 2.5. It blows 40 after about 45 min. driving on max air. New compressor, drier, blue orifice, 8oz pag, 4 seasons retro #26601, flushed condenser and evap. im happy
holdtyte
03-23-2014 06:16 PM
rickthefix
1997 - 2003 F150
05-28-2011 09:48 PM
70_RangerXLT
07-21-2010 02:33 PM
wcreay
08-14-2006 10:09 PM
arjr111
04-15-2005 10:13 PM
Quick Reply: A/C refrigerant capacities - 87 F150
