351M/400M Intake Manifold Swap. . .couple quick ?'s
Old 12-17-2010, 09:06 PM
danlee's Avatar
danlee
danlee is offline
The crossover allows exhaust heat to warm the manifold & fuel charge for fast warmups in cold weather. It's not needed for normal driving. The blockoff plates allow you to prevent the heating of the manifold, for increased power. A cold manifold = power, a hot manifold = economy.
The valley pan prevents oil from coking on the underside of the hot manifold. The burnt/coked oil is a contaminant in your motor oil, and can cause premature engine failure. If you eliminate the valley pan, you MUST use the blockoff plates to prevent the manifold from getting hot enough to coke the oil. If you use the valley pan, then you can use the blockoff plates or not.
Old 05-08-2014, 06:15 PM
elephantman's Avatar
elephantman
elephantman is offline
When putting in the valley pan. Do I put a bead of Pro Seal on the heads, install the pan and the a bead around the top side of the pan as well, for the manifold to seal?
Old 05-08-2014, 06:38 PM
danlee's Avatar
danlee
danlee is offline
No, you do not need any sealant on the Valley Pan. The pan is made to seal the intake manifold.
chuffer
13
07-24-2017 08:44 PM
kr98664
05-14-2017 09:08 PM
PapaBearYuma
04-30-2017 01:12 PM
Rusty_S
06-22-2016 07:52 AM
newt79-99
04-18-2006 01:27 AM
Quick Reply: 351M/400M Intake Manifold Swap. . .couple quick ?'s
