Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 08-09-2010, 07:12 PM
kjk kjk is offline
Garage is empty, add now
kjk is starting off with a positive reputation.
Engine code P0420
Read and cleared engine code P0420. I drove it for a few days and the engine symbol is back on my dash. I have not read the code today, but feels like a P0420.
Ideas
2007 Expedition EL
  #2 (permalink)
Old 08-10-2010, 06:17 AM
slc10844 slc10844 is offline
slc10844 is starting off with a positive reputation.
Why do you say it "feels" like a P0420? The code is for B1 catalyic converter. There a quite a few possible causes.
__________________
2013 Explorer Limited
87 Ranger, XLT
  #3 (permalink)
Old 08-10-2010, 06:12 PM
kjk kjk is offline
I should say I think it is the same code.
There are a few possibilities and I am hoping to narrow it down if possible. Is it an O2 sensor or has someone had other troubles after getting this code?
Kevin
  #4 (permalink)
Old 08-11-2010, 05:21 AM
Unless you have a scanner that can monitor the O2 sensors, I would replace the sensors. The ECM monitors front and rear sensors, and compares readings to determine if the converter is doing its job. Does the vehicle have, or ever had, a misfire problem? If not repaired quickly, the converter can be damaged and cause a cat efficiency problem that may not show up for some time
__________________
87 Ranger, XLT
  #5 (permalink)
Old 08-11-2010, 04:51 PM
kjk kjk is offline
No scanner to monitor, no misfire problems.
Is this O2 sensor just behind the drivers side exhaust manifold?
  #6 (permalink)
Old 08-12-2010, 11:37 AM
B1 is the passenger side. The heated sensor is between the exhaust manifold and in front of the catalyic converter.
__________________
87 Ranger, XLT
Tags
0420, 1999, 2000, 2001, 2006, b1, code, diagnostic, engine, expedition, expeditions, f150, ford, lightning, lincoln, navigator, p0420, po420
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
