1991 5.8L engine internals?
I will be acquiring a 5.8L from a 1991 Bronco to install in my 77 F150 EFI and all. I would like to know what to expect for longevity of this engine. Mileage is unknown. My main question is does this engine have cast pistons? I thought the first year for hyperutectic (spelling?) pistons was 1992, anyone know for sure? The reason I ask is if I mod this engine ie GT40 heads and a cam, non-roller I assume, can I expect the pistons to live through it?
Thanks
Matt
Thanks
Matt
It doesnt matter what the piston is made of, itll be fine with the combo you list. Its only when you start throwin a good bit of boost or nitrous at em that the cast and hyper pistons start havin issues. For a HCI motor you can rest assured that itll be ok. As for the rest, the rods are STOUT from the factory. Im almost down puttin together a 12:1 compression 393 stroker for my 90 mustang that is using stock truck 351 rods with ARP studs and im not loosin any sleep. Tear the motor down, inspect it for odd wear patterns and if you have time and $, rebuild it while its out using the stock parts and itll be ready to rock!!! Good luck with it!
Matt
Matt
Thanks for the replies. I will probably use it in stock form for a while. I forgot about the head bolt side differences from 5.0 to 5.8, my plan of getting junkyard Gt-40s from an explorer is foiled without paying to have the bolt holes enlarged.
Anyone have any experience with an Explorer roller cam added in an otherwise stock 5.8?
and besides having someone drill out the bold holes shouldnt cost much.
on
That's what is in the '94+ 5.8 motors, but you'll need some expensive linkbar lifters to put in it the older non-roller block. Besides the Crane 444232 flat tappet is much better suited to the 5.8 and yes it is SD friendly.
Freddie Murphy
16
10-20-2015 12:46 PM
Ecarlton1991
08-14-2011 06:20 PM
rockcrawler_101
11-16-2009 04:03 PM
ckchevyman26
08-18-2003 11:45 AM
