rear end and drive line chatter
my 350 drw long bed has a chatter when taking off pulling my 14k toy hauler worse if in a turn took it to dealer today there is aservice bulletin on diff chatter on limited slip straight line chatter is to be deturmined but drive line angle under load is suspected has any one else had or heard of similar problem
this is a driveline angle issue. Happens on 08-10 models as well. When you put that much in the bed of the truck, it sags too much.
Product of weaker springs. So helper springs or airbags for those heavy loads will take care of the issue.
preference to the airbags with onboard compressor. Then you can air up tires too.
Tectron1
04-10-2015 10:54 AM
daningraham
11-26-2014 05:11 PM
78ford351m
34
02-16-2009 05:44 AM
