T444E B10 and B50 life? - Ford Truck Enthusiasts Forums
Old 08-09-2010, 11:40 AM
bama29fan's Avatar
bama29fan bama29fan is offline
bama29fan has a very good reputation on FTE.bama29fan has a very good reputation on FTE.bama29fan has a very good reputation on FTE.bama29fan has a very good reputation on FTE.
was looking at this site
International T 444E Specifications
and read this...
Additional T 444E Information:
  • The International T 444E has a B10 life of 200,000 miles & a B50 life of 350,000 miles.
What exactly does that mean??? I read it as at 350K it is half used up. so it goes down hill fast between 200K and 350K.
I know there are a few guys here that are at or near the 300K mark and seem happy? so what gives?
Old 08-09-2010, 03:30 PM
aklim's Avatar
aklim aklim is offline
aklim has a very good reputation on FTE.aklim has a very good reputation on FTE.aklim has a very good reputation on FTE.
I'd be curious as to how they came up with those numbers. After all, in small print it also says "No affiliation with Navistar, International engine corp, or Ford Motor Company."
Old 08-09-2010, 04:55 PM
Sheldon Plankton's Avatar
Sheldon Plankton Sheldon Plankton is offline
Sheldon Plankton has a good reputation on FTE.Sheldon Plankton has a good reputation on FTE.Sheldon Plankton has a good reputation on FTE.
Quote:
Originally Posted by bama29fan View Post
....What exactly does that mean??? I read it as at 350K it is half used up. so it goes down hill fast between 200K and 350K....
I think you misunderstand the terms being used. (If I'm understanding you.) This doesn't mean that any given engine has 90% of it's life left at 200k mi. but only 50% of it's life left at 350k mi. It means that at 200k mi. 10% of the engines can be expected to need a rebuild, and at 350k mi. you can expect 50% of the engines to need a rebuild. Statistically, its not the same thing.
Old 08-09-2010, 05:08 PM
aklim's Avatar
Quote:
OK. I googled it and came up with the answer. 10%, at 200K will require cylinder head removal or pan removal, statistically speaking which is what International considers a major repair.
Navistar's definition of major repair to an engine is when the repair requires removal of the cylinder head and/or the oil pan
http://bellaphotographics.com/FordSu...%20Cummins.pdf
Old 08-09-2010, 09:11 PM
bama29fan's Avatar
great find!!!! and thanks for the answer
Old 08-09-2010, 09:23 PM
rat49f6's Avatar
rat49f6 rat49f6 is offline
rat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to behold
heck those oil pans rut out before the first oil change up in the north east so i believe that
Old 08-09-2010, 11:26 PM
BrockwayMT BrockwayMT is offline
BrockwayMT is starting off with a positive reputation.
Nice article but I'd still prefer an ISB, especially in a medium duty truck.
'66 Crew Cab... xgkrx 1961 - 1966 F-100 & Larger F-Series Trucks 49 04-01-2016 05:16 AM
FYI 99'-03' f250 leveling kit!! bth2278 1999 - 2003 7.3L Power Stroke Diesel 0 10-11-2013 07:16 PM
'65'66 Crew Cab Wanted... xgkrx WTB - Ford Trucks & other vehicles 1 01-02-2013 05:10 PM
Excursion Diversion/Ford Truck Rally July 16-18 2010 X_Hemi_Guy Excursion - King of SUVs 63 08-17-2010 01:01 PM
ID this tranny F250army45d Clutch, Transmission, Differential, Axle & Transfer Case 4 06-27-2010 06:40 PM
Tags
444e, 54l, 73, b10, b50, cover, definition, diesel, engine, exploded, ford, front, international, life, specifications, t444e, view
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
