My lifted 2WD F250 - Page 4 - Ford Truck Enthusiasts Forums
My lifted 2WD F250
  #46
Old 11-01-2010, 02:11 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is online now
ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.
Quote:
Originally Posted by mdr617 View Post
Did you say 4" lift? I thought they only make a 3", and a 16" kit? Also, how do you think the 3" kit would make the truck sit? That is what im worried about, i want to level my truck cause the front is like 2-3" lower than the rear, but i do haul stuff like firewood, stuff to the dume, dirt, gravel, and i dont want the front to be higher than the rear. But yeah, i was looking at the 3" kit. How does a truck with stock rear suspension sti with it?
They make a 3", 4" and 5". the 16" kit you are talking about is the amount of wheel travel he claims - not the amount of lift. The 3" kit would probably make the front of your truck just slightly higher than the rear.
hippie?.....
Cheeto the wonderful redneck decided that since we live in California and like desert trucks we are all sand sucking hippies. this started with me and has now seemed to move on to any lifted 2wd from out here...
It's ok though - he's just jealous of our rust free rides!
  #47
Old 11-01-2010, 05:04 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow crazyredneckanyhow is offline
crazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud of
I hate rust. Makes me miserable. I would prolly have a lifted 2wd dd if it wasnt for the snow here.
  #48
Old 11-01-2010, 08:06 PM
mdr617's Avatar
mdr617 mdr617 is offline
mdr617 is starting off with a positive reputation.
So, you said with the 3" kit, i would have to lift the rear? How much, like an 1" or something? What would you reccomend? Cause i kinda planned on buying it after christmas. Blocks, ad a leafs, new springs? I thought it would level it...now in confused.
  #49
Old 11-01-2010, 08:53 PM
teds74ford's Avatar
teds74ford teds74ford is offline
teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.
I would suggest lifting the front, and then measuring the rear to see how much it would take to make it look the way you want. While not the absolute best, I wouldn't be afraid of blocks up to 3"(4wds came from the factory with them) on a budget ride
  #50
Old 11-01-2010, 11:45 PM
76Hauler's Avatar
76Hauler 76Hauler is offline
76Hauler is gaining momentum as a positive member of FTE.76Hauler is gaining momentum as a positive member of FTE.
^^ I have to agree, do the 3" in the front first. Call or e-mail John at Autofab, and see if you can upgrade his "Econo-lift" to also include the extended radius arms. I think with the 3" in the front, e-rated 285-75/16, 33's, you'll be happy. I've also noticed that a by-product of having my truck a little higher in the front, I'm much more comfortable driving it. I don't feel like I'm pushing my head back to see forward. I just did a 4-hour trip in mine, and it was great.
As far as being a Hippie, well, I guess it's better than being a goat gaffler. Do goats even like cheeto's? Is that how ya lure them in? No please, don't answer that...... lets just talk about trucks, hugh?
  #51
Old 11-02-2010, 09:00 PM
teds74ford's Avatar
Quote:
A fellow user here, Scottfreeman, and I were talking about this very thing. I think there's also the benefit of a slight increase in caster, as well as less weight transfer under braking, all making for a better handling truck. I personally like the rear slightly higher (as far as looks) but can see how the ride and handling from a more level truck could be superior.
  #52
Old 11-02-2010, 10:38 PM
76Hauler's Avatar
I also like trucks with a slightly higher rake in the rear, sometimes. I know I'm sportin the Cal-look, but to be fair I have not put in any rear suspension upgrades yet.
As far as the longer radius arms, they certainly do make a nice difference. With the stock radius arms, any lift will "pull" the beams back slightly, increasing bumpsteer. Autofabs, at least in my application, actualy pushed the beams forward 1". Slightly noticeable in apperance, deffinatley noticeable in driveability.
  #53
Old 11-03-2010, 07:32 PM
teds74ford's Avatar
For you prerunner guys, are the chevy 63s considered any good? I know that people like them for their flexiness, but don't know much about their application in desert running.
  #54
Old 11-03-2010, 07:37 PM
good in stock form or what? The longer spring length does make them a little more "flexy" but flext comes from a couple different things. Generally for this more thinner leaves are better than fewer thicker ones - like most stock packs. There are many guys out there that are taking the chevy main leaf and then building their own pack using F-150 and jeep leaves as they are thinner. Sometimes they are re-arching the chevy main and others - sometimes they are not. If you want some reading PM me and I'll kink you to a couple threads on this on desert forums I frequent.
  #55
Old 11-08-2010, 01:12 PM
So Jason is taking the Hauler to the Barstow cleanup this coming weekend and wanted to get a skid plate on the thing before we (I'm riding with him) went. He came over Friday after work and we fought my shop and the tool nightmares (broken bender, TIG pedal, etc. etc.) to get the thing pretty much done. He'll throw on the aluminum before we go and all should be good!
[IMG]http://www.gofastbroncos.com/forum/download/file.php?id=1708[IMG]
  #56
Old 11-08-2010, 08:59 PM
Nice work as usual steve. I really like that
  #57
Old 11-08-2010, 11:02 PM
76Hauler's Avatar
Yea, thanks Steve for breakin' away from your projects to fit mine in. The kool part is, it's a bolt in piece now, can be removed for maintenance. The tool gremlins tried and tried to stop us, but Steve fought the good fight and kicked that ol' tube benders ***! Sledge hammers are such a delicate tool.
  #58
Old 11-10-2010, 03:42 PM
73FordF100's Avatar
73FordF100 73FordF100 is offline
73FordF100 is starting off with a positive reputation.
How much did you lift the rear? There's a set of 2 wheels and tires on craigslist I want to buy and put them on the back of my 2wd and they are 32s. The leafs have lift blocks about 1-2 in. thick, do you think they would clear the fenders? Thanks for any advice. I'd figure I would ask because I'm sure you know about these things.
  #59
Old 11-10-2010, 03:52 PM
I'm pretty sure at this point his rear is stock. I know I stuffed 35's on my truck when the rear was stock. Granted they would rub on the bedsides a bit, but that's nothing pulling the bedsides wouldn't fix.
One thing to be careful of though is rim width and also the offset. I run 7" wide wheels and 4.25" or so offset. Jason (76Hauler) has the same except his wheels are 16's and mine were 15's
  #60
Old 11-10-2010, 04:23 PM
What are the paint colors on your truck 76hauler?
2001 E-350 Econoline w rusted frame - scrap it? iKristian 1968-2013 Full Size Vans 7 11-05-2016 08:40 AM
Whats the difference? Fishin76 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 03-30-2015 03:48 PM
Riffraff diesel billet wheel jkidd_39 1999 - 2003 7.3L Power Stroke Diesel 159 04-14-2013 09:59 PM
BDP Fuel Sump jkidd_39 1999 - 2003 7.3L Power Stroke Diesel 17 08-03-2012 09:09 PM
Valve cover w/ roller rockers walkee 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 20 08-14-2011 09:31 AM
Tags
1970, 1974, 1979, 2wd, 76, drive, f100, f250, ford, lift, lifted, pickup, pics, superduty, truck, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
