when you start the truck up in the morning when the motor is cold,it will start fine but after it starts it idels up then the rpm goes down then stalls,have to restart the truck about 3 to 4 times before it straightens out and runs like it supposed to,what could be causing this??
Not sure i completly understand the problem. Does it start up get warm idle down then stall? if so i would guess coolant temp sensor. (don't buy anything but motorcraft or other ford recomended sensor)
i start it up in the morning when motor is cold,start the motor it revs up then starts idiling down the stalls,the fuel regulator has been replaced,plugs,plug wires,fuel filter,it has dual tanks but only use the front tank,,the fuel pressure regulator went bad and filled the intake full of gas,had to clean that all out,took the intake hoses off cleaned the throttle body out.
