Dually Tire Wear
Dually Tire Wear
I put on a new set of Michelin LTX MS2 on my truck in April.
6 wheel alignment was done.
Front Tire Pressure: 70 (Ford suggests 75)
Rear Tire Pressure: 70 (Ford suggests 60)
In the last 4 month I manager to put on ~2000 miles.
I notice that the front tire are wearing QUICKER then the rear. The rear looks like new with very little tread wear. As for the front, it has already lost 1/32.
How are you using the truck? Are you hauling much or DD?
The reason I ask is the new tires on my old work F350 DRW (2005 2wd CC) started wearing a wedge pattern in the front after a few thousand miles. The rear tires weren't affected. It was only used for hauling cars so was always loaded.
It makes sense to me for the front to go faster on a diesel-powered dually, especially if you're unloaded. The contact patch up front is appx. half the size of the rear because there's half as many tires, and when you're unloaded, the front 2 tires carry the weight of the engine while the rear 4 carry a bed full of air. More load, more heat, faster tread wear.
So let see it someone with some actual experience can verify this theory or bust this theory.
If you have a funny wear pattern I would look in to it. If the tread is just wearing fast double check the tire rating and the compound used in construction. Also check tire pressure.
