turn signal problem 2004 F250 6.0L
New to this.
2006 F250 4x4 I’m having the no turn signal problem also flashers working but no turn signal. I was able to reach and change the blue flasher by dropping my storage box. Fuses are all good. Tried to remove the steering column cover but was stop by rain.
Any advise appreciated
. Believe it or not it is fuse number 27.
ok, its fixed
all I did after replacing the relay is: press the hazard lights button on top of the steering wheel, and that reset something, not sure what, maybe the old broken relay kept something stuck, but after pressing that on and off, the turn lights now work and they show up in the dash as well, cool :- )
glad that all it took
almost 152,000 miles, this is the only thing gone bad so far, knock on wood
The following users liked this post:
Ford F-250 6.0
wow you knew exactly what he’s Turning signal problems was , I had the exact same problem and since I was riding all comments I found out your was the right one. I just changed fuse 27 which is blue15 and problem or headache solved 😁. Who knows how much the mechanic would have had charged me. Thank you so much
tylers65
01-26-2014 03:10 PM
