Locating correct center support bearing
My 2000 F150 5.4 Supercab longbed center support bearing failed (spicer also destroyed). I have been trying to locate one but haven't had any luck. Oreilly, Napa and Pepboys all offer the same bearings by SKF, part #HB88515. Everything on the center support is exactly like the one off my truck except for the inside diameter of the bearing itself. The one off my truck measures 1.375, the one from SKF measures 1.575.
Oreilly offers brands like Anchor with the correct ID but the way Anchor builds them, will not allow you to assemble the drive shaft correctly.
The bearing off the one from my truck is made by NSK with a part # 35DSF01. I haven't had any luck finding just the bearing itself either. Right now my only solution is to use the frame and spicer from the SKF and try to locate the the same or replacement bearing from NSK if its available.
Anybody have any suggestions or has had this issue? Know where to locate the correct bearing or unit?
Here is a posibility, sometimes all the vendors use the same info for their computer listed part reference and it contains an error they all will have.
Ask one vendor to look up for the a year behind and the year after yours to see if a different part number comes up.
If so, see if it can be determined if your truck may have had a running production change or was built near the end of the model year and got the next model year hardware in the build.
Saw this happen before.
Good luck.
Good luck.
After exhausting all options I tried one of those websites that say they will locate any bearing for you. I was kind of skeptical about it but to my surprise it worked.. Their website is Bearing Location Service - Timken, Ntn, Ina, Skf, Link-Belt, Dodge. I input the model number of my bearing and got a call from them within 20 minutes. Its been a while back but I believe it was about $26.00 when I bought it.
So what you have to do to make this work is you have get a hold of the center support from SKF part number HB88515. This is the only one that will work for your truck. Once you have the center support you'll have to carefully knock out the bearing that comes with it and replace it with the bearing you will get from Bearing Location Service - Timken, Ntn, Ina, Skf, Link-Belt, Dodge. Also, don't throw away your old center support bracket because your going to have take the mounting plate off the old one and put it on the new one. The holes in the new one didn't line up and was impossible to mount. Hopefully you'll get lucky and get one with the holes that do line up (test fit it to find out). It sounds like a lot to do but it was actually pretty easy to do as long as you have the right tools. The hardest part is taking apart the drive shaft to get to the bearing. I took it to a shop and had them take it apart. They can also press everything back together and then just simply install it. To knock the bearing out I used a pretty big socket. To put the new one in I used a bearing and race seat kit (so that it wouldn't do any damage to the bearing)that you can rent at Autozone. And you will also need a 33mm socket (got this at O'reilly) to tighten the the drive shaft nut. As you tighten this, it will press the bearing back onto the shaft and your ready to install once its tight.
I hope this information is useful and good luck with your project.
I did get an after market bearing from an online supplier. The site is called Locateballbearings.com. This is for the bearing only not the housing. If your housing is still good then your in luck but if it isn't then you'll have to get that seperately, and replace the bearing that comes preinstalled in it. I got an SKF housing for my truck.
F-250 restorer
04-16-2017 08:26 AM
TexasGuy001
02-03-2017 03:16 AM
Mixer man
12-23-2015 03:00 PM
F250_
28
12-21-2015 07:28 AM
jdemaris
08-15-2015 10:57 AM
