No Fuel from Injectors
I traded for a 94 F250 that a guy could not get to run. It will run if you squirt gas into the intake. New fuel pump, new pressure regulator and fuel to the fuel rail but it seems the injectors are not firing. I'm thinking a module of some type is out but I'm not sure where to look first.
on
Pull the codes to see if there is anything flagged, there isn't much that would prevent the injectors from firing but it's worth a look. If that doesn't turn up anything then disconnect the battery and then the wiring harness at the EEC(firewall near the drivers side fender) and check for continuity from that point to the injector plugs on pins 57, 58, and 59. Ford Fuel Injection
Also examine the pins and sockets in the EEC and connector to see if any are bent or pushed back.
