Who makes a performance 7.3l engine?
I will say it right now so everyone knows
I am a gasoline guy. i know a little about diesels but not much.
I recently bought a 2003 king ranch with the 6.0l. i wanted a 7.3l but for 7 grand I will take her. was in great shape and i knew its history.
It ran great for a while and i thought i stumbled across the best 6.0l ever made. then reality struck and the dreaded check the old engine light came on. then it started idleing wierd. then going down the highway it would lag a little and i'd step into it a little more to keep up my speed, then it would just kick in and go like a SOB. then my lights started strobing.
Code reader said that it was injector control pressure sensor, my local dealer said they could book it in and do it for $300 plus labour.
Now i am one of those cheap son of a guns that like to do my own wrenching, so that i know its done best and any other hick-ups along the way are dealt with also.
Then i thought well **** i want the 7.3l in there.
ive swaped plenty of motors and trannies so why not. mostly in older trucks but i am a wizz with wiring.
I thought well hell in 03 the 6.0l was introduced and the wiring has to be close with the 02 7.3l.
But i want a mean motor so my question is:
Is there any Reputable company that make a 7.3l longblock or turnkey crate. or should i get a stock crate from FoMoCo?
I plan on using a 7.3 tranny, either auto or 5 speed.
There have been some posts about H.O. 7.3's and some links to ebay but I don't remember anyone actually buying and using one. Usually if someone wants a stronger 7.3 they build it themselves. Some of the diesel specialty shops could build you one or locate one. Just have to start doing a search on the web and check local diesel shops. Sorry, not much help on specifics. Although, Black Magic in Cedar Rapids, Iowa Home Page and Clay at RiffRaff Riffraff Diesel may be able to help you.
If smog laws similar to California's ever arrive at your doorstep, you'll have to replace the 7.3 with another 6.0.
I believe this exercise will prove to be completely futile in the long run.
I'd just buy a 7.3-powered truck and be done with it.
But it's YOUR time and money......
Good luck!
Pop
Good luck!
Pop
If (and this is a really big IF ), you have the cash, Zane at Wide Open Performance has a really nice, cryo treated long block.
Wide Open Performance - Online Store
Cost: $15,600.00
If I had a spare 20k burning a hole in my pocket, that's what I'd get.
Stewart
"Our 7.3L PSD Long Block is custom built here, in-house, to the highest standards. This is the same engine we run in our 10-second F350 and our Quad Turboed Power Stroke Dragster. These will be capable of support 800+ horsepower. We start off by cryogenically treating the engine block, crankshaft, camshaft, and pistons. This short block contains performance pistons, billet connecting rods, WOP main stud girdle kit, H11 head studs, fire ring head gasket kit, new water pump and oil pan. The heads are completely rebuilt using our Hi-Rev valve springs, chromoly pushrods, hardened seats and Inconal stell performance valves. The motors are fully machined, balanced, and blue printed. It will come fully assembled ready to accept your high pressure oil system and turbocharger. For more details on this long block, please call, as custom builds to customer specs are available."
Cost: $15,600.00
Stewart
Good luck!
Pop
Good luck!
Pop
The loop hole to that is (POSSIBLY!), since both engines were offered for that model year, he could get it approved.
It's like my 1990 5.0 Mustang. They came from the factory with 302 engines, but I can put a 351 into it because Saleen put them in the Mustangs that model year too, and they were considered factory built cars, where smog is concerned.
It would have to be researched, but I bet it would be ok'd since his truck is an '03.
Stewart
Stewart
Stewart
Stewart
Good point. I didn't think of that. Mike has a good point though about the trans. Its a whole different beast.
Cost: $15,600.00
Stewart
Cost: $15,600.00
Stewart
If you wanted to keep the 6.0L there are some tech features in www.powerstrokemag.com Sept. 2009 for 6.0L Power Stroke recipes on a budget build, also in July 2009 issue, they have a tech feature "Every 6.0L problem solved", For the money you'll have trying to drop in a 7.3 you could make a dependable 6.0 since you already have the truck. just my $.02 worth
Rockaholic
6.7L Power Stroke Diesel
24
01-15-2020 10:29 AM
Cool6.9DieselGuy
12-03-2015 09:45 PM
Cmg1985
03-13-2015 02:23 AM
