how do you remove factory radio?!?!?! - Ford Truck Enthusiasts Forums
Old 08-07-2010, 08:50 PM
powerstroker100 powerstroker100 is offline
powerstroker100 has a good reputation on FTE.powerstroker100 has a good reputation on FTE.powerstroker100 has a good reputation on FTE.
I dont understand how it comes out theres just four pin holes on each side of it, its just the facory am/fm radio no tape player, I have a cd player made by kenwood here that my uncle and I pulled out of a chevy, I'm probably going to have to buy the harness connector for wiring if I cant figure out whats what for the ford wires but first how do I get the darn thing out of my dash?
Old 08-07-2010, 08:56 PM
96ford250 96ford250 is offline
96ford250 is starting off with a positive reputation.
there is a special tool you can buy its like 6 bucks at walmart in the stereo section
Old 08-07-2010, 09:00 PM
flipklos flipklos is offline
flipklos is gaining momentum as a positive member of FTE.
I use 4 roofing nails, a little tug, and its out.
Does the raido still work? I will buy it off of you if the price is fair. I cant stand the stock cassete one as it has no "tune" function. Only search. I live in a semi rural area and you cant search for stations that will come in if you lock them in their hometown. Heck, I will give you my cassete radio if you just want to trade.
Old 08-07-2010, 09:18 PM
no thanks on trading, this kenwood radio I have here is nice, please explain how you used roofing nails to pull it out?
Old 08-07-2010, 09:25 PM
f-150_1993's Avatar
f-150_1993 f-150_1993 is offline
f-150_1993 is starting off with a positive reputation.
It should give you an idea of how to use the roofing nails lol
Old 08-07-2010, 09:45 PM
Quote:
That is how you do it!
Old 08-07-2010, 09:53 PM
thanks!! so basically those go in and push back on some tabs and then you can pull it out
Old 08-07-2010, 10:37 PM
f-150_1993's Avatar
yeah basically thats what it does.
I'm pretty sure you can use other things
but that is the proper tool.
Old 08-07-2010, 10:39 PM
okay I think I'll try it with some allen wrenches
Old 08-07-2010, 10:42 PM
LCAM-01XA LCAM-01XA is offline
LCAM-01XA has a very good reputation on FTE.LCAM-01XA has a very good reputation on FTE.LCAM-01XA has a very good reputation on FTE.
So glad my truck's old enough to where the radio is actually bolted down to the dash! Even my aftermarket unit is bolted down, in the exact same fashion as the factory one too - well I did rivet the factory brackets to the aftermarket cradle
Old 08-07-2010, 10:54 PM
f-150_1993's Avatar
if it doesnt want to come out dont pull it
because it will break... :/
2008 F150 4-Door Radio/CD player will not work Fordyarddog 2004 - 2008 F150 4 07-20-2016 03:21 PM
Removing stereo in 95 E150 EconolineFan 1968-2013 Full Size Vans 3 04-15-2011 04:14 PM
6 disc cd changer problems dtingle89 2004 - 2008 F150 0 01-09-2010 03:51 PM
stario problems Dallenx Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 1 02-10-2007 12:34 AM
1984 Ford F150 In dash cd player question. mikedogg7 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 6 10-08-2006 11:40 PM
Tags
08, 1993, 2000, 2003, 2008, f150, f250, facory, factory, ford, pickup, radio, remove, removing, stereo, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
