What is the proper way to adjust F150 door latch/striker? - Ford Truck Enthusiasts Forums
Old 08-07-2010, 09:31 PM
92 Red F150 92 Red F150 is offline
92 Red F150 is starting off with a positive reputation.
What is the proper way to adjust the door striker/latch on my '92 Ford F150 truck? I looked at the FSM and it's not clear to me. I let my boy start driving my F150 about a month ago. I drove it the other day for the first time since giving it to him. Both doors now rattle against the strikers something fierce which they didn't when I gave it to him. He claims innocence.
You could grab the outside handle and rattle the latch by pushing in/pulling out rapidly. Drive it down the road and the doors rattled something terrible. The weather stripping is still in very good shape and all there. The door hinge pins appear to be still tight. So I am thinking it just needed a simple latch adjustment. So I scribed a pencil line around the current position of the "latch striker", loosened the torx "striker pin" and moved it in just a fraction on an inch. Problem is, while the rattling is gone, I have to slam the door VERY-VERY hard/multiple times to get it to latch. I tried various incremental movements back/forth of the torx "striker pin" and I either get a rattling latch or I have to slam the door very hard. In the first picture, how is the part labled "latch striker" supposed to be adjusted? If you loosen the "striker pin", it allows the "latch striker" to rotate. Obviously, I think it is supposed to fit into the wedge section of the "door latch" pictured in the second picture. Is this supposed to be an even fitment? Do you snug down on the torx striker pin, gently close the door to position the "latch striker" properly then tighten down on the torx "striker pin"? Do you line the "latch striker" perfectly level? Is the "latch striker" used to move the door up/down incrementally by cheating it a few degrees up/down to position the door in the door frame? I would appreciate the experts to tell me how you guys adjust the door latch properly so I can get rid of the rattles and not have to slam the door so hard to get it closed. Thanks, Charles.
[IMG][/IMG]
[IMG][/IMG]
Old 08-07-2010, 10:48 PM
86F150302's Avatar
86F150302 86F150302 is offline
86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.
Im still playing around with mine.. I finally got it right. I just kept messing with them until I was happy.
Old 08-07-2010, 11:15 PM
wickedklown83's Avatar
wickedklown83 wickedklown83 is offline
wickedklown83 is starting off with a positive reputation.
is the plastic bushing that goes around the stricker still there??? if and when they fall off it will cause a hell of a lot of noise.... you can get the replacement strikers at a parts store in the "HELP" kind of stuff, just get a torx bit that fits yours OR use my pethod of vice grips and spin them out, spin the new ones in in the same exact spot with bushings
Old 08-07-2010, 11:43 PM
Quote:
Wicked, thanks for the reply.
I bought the truck with 80K miles on it and I can honestly say that I don't remember there being a plastic bushing on either the drivers or pass side striker pins. But if '92 F150's should have them then that explains why it may be rattling. Here's a couple of pictures my boy took for me this afternoon. It's dark out now so I can't look closer but in the pictures below, it looks like there's no plastic sleeve over the striker pin. If there's supposed to be plastic over the metal striker pin on a '92 then I will buy a couple of new pins this coming Monday. Here's the pictures of the pin my son took today, looks like no plastic sleeve right?
[IMG][/IMG]
[IMG][/IMG]
Old 08-07-2010, 11:50 PM
yeah i would definately say no plastic on them left, heres a pic i stole from autozones website for a 92 f150 at 8.99 each
edit. judging by the second pitcure it looks like it just recently lost the plastic, you can see a nice clean circe right around the pin
Old 08-08-2010, 12:03 AM
Dang, looks like both sides are missing the plastic! I'll be getting a couple of new pins this Monday. Wicked, thanks for the solution.
Old 08-08-2010, 12:06 AM
not a proble,. just glad to help instead of always being the helped lol
Old 09-20-2010, 12:51 PM
SLAYER1 SLAYER1 is offline
SLAYER1 is starting off with a positive reputation.
I need to replace both of mine on my 94 Bronco, can the nut inside the B pillar fall down inside when you remove the striker or is it held in place?
Old 09-20-2010, 01:58 PM
It did not fall down when I did mine. The new strikers solved my problem.
Old 09-20-2010, 02:05 PM
thanks Red, where did you buy yours? I found them on LMC for $12.95 each plus shipping
Old 09-20-2010, 02:19 PM
86F150302's Avatar
Quote:
Autozone Help section for $8.99
Part Number:
38448
Old 09-20-2010, 02:24 PM
thanks Red, rep points to ya
Old 09-20-2010, 02:26 PM
thanks 86, points to you as well
Old 09-20-2010, 02:27 PM
86F150302's Avatar
Back at ya bud
Old 09-20-2010, 02:49 PM
Encho's Avatar
Encho Encho is offline
The Southernmost Mod
Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.
It's funny how the driver's side gets a lot more strikes yet they tend to fail almost at the same time, i think that speaks very well of the quality of the materials used on them.
Door Striker cobrafromhale 1987 - 1996 F150 & Larger F-Series Trucks 16 12-31-2016 09:38 PM
Help-can't open either door mike41a 1987 - 1996 F150 & Larger F-Series Trucks 16 03-02-2015 11:27 PM
rattle tattle tattle doors driving me crazy adjustment Skip1970 1968-2013 Full Size Vans 4 01-28-2015 02:29 PM
Door striker post/bushing replacement grasfarmr73 1973 - 1979 F-100 & Larger F-Series Trucks 1 01-22-2015 10:55 AM
Tailgate "Electrical Problem" Solved !!! Tim Hodgson 1978 - 1996 Big Bronco 3 06-10-2013 05:34 PM
Tags
150, 1996, 97, adjust, adjustment, back, bronco, door, f150, f350, ford, hinges, latch, rattle, striker, taurus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
