What did you do to the X today?
Reason I ask, when between acceleration and deceleration, I get a "bobbling" from the rear. I've done everything else, driveshaft, rear wheel bearings, balance....I guess its the center. It still locks thought, went a bit sideways in the rain when the turbo spooled. Lash maybe? 197K. Trying to avoid catastrophe with a little PM.
Question on this: Can I just remove the center, replace the clutches and reinstall without issue?
When you jack up the rear end check the backlash of the driveshaft input compared to the axle movement. If it is excessive it is possible the clutches are gone.
Once you pop the diff cover it should be pretty obvious. Check the backlash again with the cover off and see if the spiders are loose (not a worn pin or other problem) against the clutches.
Yes the diff can be pulled out, new clutches installed, and reinstalled. Make super duper sure the diff shims go back in their same side/spot. When you loosen the diff, pull the shims out of one side and zip tie them together and place on (or around) the rear end on the side they came out of. Same with the bearing races.
LOLOLOL, ya know, if the stars ever align and Michael decides to sell his Ex, and I can properly plan for an armored truck to drop a money bag for me so I can buy his Ex, and his black beauty becomes my black beauty, I still wouldn't take any pics of the underside and post them here!
Stewart
Stewart
did front brakes and rotors today
I did my front brakes and rotors today. I needed to get rid of a warped rotor that was on it when I bought it. Well I am paying for doing it today. It was in the 90's today not too bad but being a disabled veteran, my back and knees are not happy. I hope moving tomorrow isn't a problem. My slide pins were in good shape except for one that didn't want to move at all. I wish I had a wire wheel......I got it cleaned up and lubed all the zerks. Steering seems to be better but it could just be my imagination. Sorry no pics, I was lucky I was able to finish and get in the house. But I still would count it as a good day, a bad day working on the excursion is still better than working on a chevy
I knew you could be happy to see it, I just hope it means a heavy snow season for us. I have a BUNCH of Boss plows to sell at work...hoping for sales!
