What did you do to the X today?
I hope the current owner knows that! I'm from San Antonio also...welcome to the EX portion of the forums.
Getting all loaded up to go hunting next week. Opening day is Saturday, but the weekend is OT, and I ain't giving that up! So heading out Monday morning. Worked out anyway, rest of the hunting party really can't leave till then anyway. Truck is running great. Transmission rebuilt, new flex plate, and I also had a bad u-joint..all taken care of.
I did strong arms for the 2wd height last year. I like them. My only complaint is how fast and hard they slam the hatch all the way up. It's a bit violent compared to the soft opening of the factory struts.
These are matched by length, link type and pressure from the buyers guide in the stabilius catalog. Not the strong arm units. These are very smooth open and close.
Drove mine to Arlington Natl Cemetary for a funeral. After the funeral we went to eat in Crystal City and i had to go onto a parking garage. The antenna was hitting the low pipes, the roof cleared by inches. It was nerve wracking.
After lunch we drove into DC, a big Suv is out of place in that city. Some guy on a Prius had to roll his window up because he was next to my tailpipe.
I only saw one other Ex today, it is on the side of the road with a broken ball joint.
Thats kinda nice! I did in fact notice at the store, that in fact the rear hatch does not open up very high, it barely clears my head and that with lift ad 35's! I like this idea!
Had a few issues today....
Installed my HPOP, fired it up, had it idling, free revved it, all is good, ran for prob 45 min total. Went for a test drive around the block, it died as I pulled into the driveway. Wouldn't restart..... Checked the torque on the HPOP drive gear, all good, unplugged the ICP sensor, cranked a bit longer n it fired up. Drove it all over the place since than n shut it off and started it prob 15 times. All seems good.
Air bubble or what???
Really?? I was worried as hell for a little bit there. After I put the pump on, mine fired up second try, and ran smoother than ever within a couple min. It just didn't make sense to me! If it's common, I guess I won't worry. Especially since it's running now! Lol
Ok, cool, it seems to be all good now, I drove it like I stole it for about half a hr, and it all seems good. Going to drive it to town today n clean the engine up good so I can make sure I fixed the leak, and more than likely find more leaks. Lmao. I left my wheel wells out so I can clean the whole engine up nice.
I cleaned up and put stuff away and went to start it for my test drive and it took two or three times to get it started. I drove it all day and the next day, once again, it took a couple times for it to start.
I haven't had any hiccups since.
When you mess with injectors, fuel systems, fuel lines, HPOP, HPOP rez, HPOP lines, etc, things can be a little out of whack for a couple days.
Stewart
My uncles garage is littered with instantfire, I've read a lot of posts on here about how to keep it away from diesels, but in practice it would appear to work just fine without any serious repercussions. Brake fluid on the other hand... I've heard one started with that and it will run away on that like crazy. I expected the engine to be toast after hearing it, never had heard anything like a Detroit diesel running away on the tach.
