What did you do to the X today?
Old 03-31-2015, 02:55 PM
RobRoss's Avatar
RobRoss
RobRoss is offline
Originally Posted by IMASAP
So today I was trying to assess what needs to be disassembled to swap front springs (I have the springs... getting itchy). Looks like the front spring eye bolts go in from the inside out, and removing them may require either removing the crash bar, crash bar brackets, and the front spring hanger from the frame, or ??? Looks like the radiator support is in the way of removing the spring eye bolt. I tried looking through a couple threads, but couldn't find an answer.
Any free advice from someone who has done front springs on their Ex ?
Just remove the front bumper and pull the spring out that way. The driver side rear spring eye bolt will touch the driveshaft but you can get it out. May have to raise/lower the axle to get it out. Once the new spring is in, install that bolt the opposite way (in case you need to do it again).
  #33602
Old 03-31-2015, 03:19 PM
mecdac's Avatar
mecdac
mecdac is offline
X 2 on bumper removal or add two hours and three beers to the job.
  #33603
Old 03-31-2015, 04:22 PM
02expy's Avatar
02expy
02expy is offline
we took our EX on a little adventure trying to get up to our favorite camping spot north of Priest Lake ID, and found A lot of snow. we got 5 miles up the NFS road till it got too soft and deep. here are some pictures and videos of it, on the way down we found a Rav4 that was stuck.
we hiked up a few miles, but all in all not prepared to play in the snow but the kids had a good time.
  #33604
Old 03-31-2015, 04:34 PM
05MilMachine's Avatar
05MilMachine
05MilMachine is offline
I will add to removing the front bumper, your front eye bolts may contact the brackets that hold the condenser in. One bolt each and they come right off. I did my fronts in about 3 hours with a second person helping me to stab the eye bolts back in while I pryed things into place.
  #33605
Old 03-31-2015, 04:47 PM
IMASAP's Avatar
IMASAP
IMASAP is offline
Thanks, pulling the bumper off is no problem. It just doesn't look like the front spring eye bolt will clear the radiator support when I slide it in toward the center of the truck to release the spring, but if you guys say it will I believe you. I may tackle it this weekend if the weather is good.
P.S. I know you posted pics when you did yours. Can you direct me back to those pics?
  #33606
Old 03-31-2015, 05:19 PM
IMASAP's Avatar
IMASAP
IMASAP is offline
A brown truck stopped by today to drop off my new Toyo Open Country AT 2s.........
  #33607
05MilMachine
They are earlier in this thread, I don't know how to link to pages in a thread. My pics weren't as detailed as I would have liked, I was jobbing and being charged hourly for the stall I was using. Its a lot more straightforward than it sounds. I dreaded it for a while before just doing it. The hardest part about the front springs was getting the axle back lined up under them. Ratchet straps or a come along go a long way towards this. With x codes I believe im on the bleeding edge of needing a new adjustable trac bar, as it pulled pretty tight to line things up. Good luck!
  #33608
Old 03-31-2015, 05:21 PM
IMASAP's Avatar
IMASAP
IMASAP is offline
Next to the 265s on the truck now
  #33609
Old 03-31-2015, 05:24 PM
IMASAP's Avatar
IMASAP
IMASAP is offline
I'm installing Pro Comp 22210s. At least I was smart enough to order a Zone Off Road adjustable track bar. I'll be installing it at the same time....
  #33610
Old 03-31-2015, 05:28 PM
fordboy67's Avatar
fordboy67
fordboy67 is offline
02Expy, sweet pics, that's some beautiful scenery!
  #33611
Old 03-31-2015, 05:36 PM
05MilMachine
I have an adjustable one on my list. I could probably use the new bushings it has as much as the adjustment. Looking forward to seeing yours with those new tires.
  #33612
Old 03-31-2015, 06:11 PM
sfoltz's Avatar
sfoltz
sfoltz is offline
What size are those Toyos?
  #33613
Old 03-31-2015, 07:18 PM
IMASAP's Avatar
IMASAP
IMASAP is offline
295 / 75 / 16E
  #33614
Old 03-31-2015, 07:23 PM
Drunken_Unicorn's Avatar
Drunken_Unicorn
Drunken_Unicorn is offline
New mirrors. Bwahahaha!!!!
  #33615
Old 03-31-2015, 07:31 PM
sfoltz's Avatar
sfoltz
sfoltz is offline
295 / 75 / 16E
NICE! Can't wait to see those on your EX.
Quick Reply: What did you do to the X today?
