What did you do to the X today?
very much so...smells like home! also "cleaner" lol
Felt so good to drive one of my trucks after having the mustang for 3 days. 435 miiles and 18.5 gallons of gas comes out to 23ish MPG? Pretty dang good i think and i have to say that 3.7 V6 did have some get up and go...sport mode helped also
My little girl loves it
Sorry Texas, but I'm a changed man. Virginia has been good to me and I'm not coming back. I love her and she loves me, she treats me right. The traffic is better, the people are nicer... and the air is the cleanest out of all 50 states. This graph below shows it in detail and is scientifically accurate:
When the wind is just right from the dairy farm down the road, it smells just like Texas air around here sometimes.
Man that Texas air is the best said everyone ever! But then I moved to Virginia and started hiking.... 8 miles up and I get this:
Same here, but I got to go on the highway! I almost never (like once a month if that) have a need to and I got the slightest bit of road noise from my tires!!! I know it's an extremely little thing (31's) compared to you guys but I felt 50 feet tall I also took some new pictures since I decided (well the wife did) that I should ditch the running boards.
Ended up pulling the foglights off so I could bake them to open em up and clean them out. Hit a massive puddle that blew out both the bulbs so I had glass, sediment and condensation in the bulbs. The little bulb shrouds had also broken off and were bouncing around inside the reflector. A bit of a tedious PITA to do with the bumper on. I just took the brackets off the bumper then manipulated them around to get the foglights off the brackets ( two plastic push tabs and the adjustment screw per light), then the housing can get removed through the lower grill opening. Not having a front plate helps immensely.
For future reference in case anyone wants to do the same, 180* for 13 minutes works well for loosening the OEM sealant (rubber butyl I believe?). Used a few small flat head screwdrivers to leverage under the lense and pry it up, gotta work fast because the sealant sets back up very quickly. Washed out with soap and water, air dried, and threw some desiccant behind the reflector (some careful prying required) and resealed with RTV Blue and done.
