What did you do to the X today?
Old 08-20-2014, 09:54 AM
Jmatthews's Avatar
Jmatthews
Jmatthews is offline
is a BAAAD MAN
Originally Posted by Chartneck
Thanks Bently,
Yes I looked at the RAS and the Airbag. I kinda lean toward the Airbag, but the RAS is very interesting. Just not sure if I will need it.
I'm still a little confused on how this will sit with the AAL in the front and the "B" springs in the back. I think based on the other threads in here, I will end up with about 1.5-2" higher in the front with the 2" X blocks on back, but pretty even with the F350 blocks. We'll see. I'm ok with an inch or so rake in the back. I just don't want to be higher in front. If those AALs ride too rough, I'll hunt down some V springs for the front.
I don't have any rear sway bars yet, but yes it will probably need them too.
Yes, I did see the SPD Y pipe mod and am curious if it really makes a difference. To me, before doing that, it makes sense to put in a high flow cat and high flow exhaust. I mean the stock Y pipe has narrower openings than the rest of the exhaust but it's hollow. From what I have read, the most restrictive point in the whole OEM exhaust system is the cat. In a perfect world I would have the money to do it ALL! Oh well...
Thanks for your suggestions, all are worth a consideration.
RAS will raise the back 1 1/2 inches give or take, you set it and forget it and makes the ride much smoother even when not loaded. It also helps eliminate sway some by stiffening up the springs so you may not need a sway bar. I don't have a sway bar and I tow a lot.
It's a really good compromise between new rear springs/airbags/sway bars.
Good luck and welcome!
  #28412
Old 08-20-2014, 02:02 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
did my driveway alignment...much happier with a properly aligned steering wheel.
Originally Posted by USCG_PA
I did find out today that I will be able to keep feeding her as I am going to be promoting to a higher rank on Sept. 2. On that day, I will be pinning on the rank of Chief Petty Officer, E-7, and for those in the Coast Guard and the Navy, that is kind of a big thing. All I can say is that I am honored to make that rank, and my Ex is grateful for the pay raise that comes with it.
Welcome to the fold brother! You're still a target to me...but I hold you in higher esteem now
-Machinist Mate Chief (SS)
  #28413
Old 08-20-2014, 03:29 PM
USCG_PA's Avatar
USCG_PA
USCG_PA is offline
Hey now, no friendly fire. Besides, there is a possibility that I might get stationed in Honolulu, and then you will have to put up with having me on the island... If I do, I am not sure I will ship the Ex out, shipping a car is not a cheap thing. I might end up leaving it state side with my folks. Anyways, that is something that I will just have to wait decide on, if my orders send me that way.
On a side note, do you know why Navy guys have such good looking kids? It's because the Coasties take care of the home while they are away at sea!
Just a little humor from a Puddle Pirate
  #28414
Old 08-20-2014, 03:34 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
It's $1000 to ship a car from West Coast to HI. Bring your X!
  #28415
Old 08-20-2014, 04:18 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Stewart
  #28416
Old 08-20-2014, 05:20 PM
USCG_PA's Avatar
USCG_PA
USCG_PA is offline
Ah the Guardian... I hated that movie.
But I guess it could be worse...
<iframe width="960" height="720" src="//www.youtube.com/embed/ekXxi9IKZSA" frameborder="0" allowfullscreen></iframe>
As they say, it is not gay underway, it's just hooking up a shipmate.
  #28417
Old 08-20-2014, 06:07 PM
miko6810's Avatar
miko6810
miko6810 is offline
I've had some extra time at home since my Semi-Truck is getting a rear end replaced. While picking up my order of Schaeffers 293 DIff Lube for my truck, i also picked up 8qts of Schaeffers 9000 5w-20 motor oil and decided to change the oil.
since i was also changing the oil in my Semi, i picked up a nice Cummins Filtration LF16002 Filter.
as you can see, and much to my surprise, Schaeffers oil is Green in color ( i've heard that Brad Penn oil is too but i've never tried it )
fun day!! now get out there and show your X sum love
  #28418
Old 08-20-2014, 08:38 PM
LivingLarge's Avatar
LivingLarge
LivingLarge is offline
Originally Posted by Stewart_H
What all got messed up?
Stewart
Receipt out in the EX, I'll post the parts list tomorrow.
  #28419
Old 08-20-2014, 10:52 PM
Mr.Nobody's Avatar
Mr.Nobody
Mr.Nobody is offline
Started here at the house, spent the weekend down by Westport, WA.
Ended up at SeTac Airport with my 30 foot Airstream
Man that pissed some people off. Was only there for like 5 minutes, and I didn't park any cars in or anything. Lots of "Look at that crazy white boy" coming my way from many of the airport staff.
  #28420
Old 08-21-2014, 12:00 AM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
OMG the SeaTac airport is crazy place in a midsized car! I would not have wanted to be you!
  #28421
Old 08-21-2014, 12:36 AM
Stewart_H's Avatar
Stewart_H
What, you aint proud about going out in hurricanes that will ground the Navy???
Stewart
  #28422
Old 08-21-2014, 05:56 AM
Jigger2020's Avatar
Jigger2020
Jigger2020 is offline
Received 5,160 Likes on 1,689 Posts
Good one Mr N, well done
  #28423
Old 08-21-2014, 07:13 AM
carbon coupe's Avatar
carbon coupe
carbon coupe is offline
Uh oh, there was a box on my porch yesterday that was packaged with this curious yellow tape. It has some strange blue rubber tubes in it. Looks like I'll have to figure out a place to put them this weekend. DAMMIT!!
  #28424
Old 08-21-2014, 07:27 AM
mecdac's Avatar
mecdac
mecdac is offline
Let's see some pics of inside the AS.
  #28425
Old 08-21-2014, 08:53 AM
LivingLarge
Stewart
Parts needed for the repair...
40 YN*19* Refrigerant -R-134a
1 5C7Z*19D850*DA Tube- compressor to Manifold
1 6C3Z*19C836*B Accumulator asy-ac
1 F5UZ*19D990*AB Restrictor
1 4C7Z*19V703*AB compressor asy
1 4C3Z*8A616*AA clutch asy-fan
Quick Reply: What did you do to the X today?
