What did you do to the X today? - Page 8 - Ford Truck Enthusiasts Forums
  #106
Old 10-31-2010, 09:40 AM
Snowseeker's Avatar
Snowseeker Snowseeker is online now
Snowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputation
Getting to be that time of year to clean up and store the X. I am going to miss it over winter.
  #107
Old 10-31-2010, 02:57 PM
slenser slenser is offline
slenser is gaining momentum as a positive member of FTE.
Quote:
Heck, I'm looking forward to my first winter with it. I'm thinking it will rock in the snow!
  #108
Old 10-31-2010, 07:44 PM
jdw1's Avatar
jdw1 jdw1 is offline
jdw1 has a great reputation on FTE.jdw1 has a great reputation on FTE.jdw1 has a great reputation on FTE.jdw1 has a great reputation on FTE.jdw1 has a great reputation on FTE.
Quote:
They do rock in the winter!
I have two X's also and never divorced!
  #109
Old 11-07-2010, 08:16 AM
Snowseeker's Avatar
Cleaned the wheels and tires yesterday. Had oil all over them from oiling the lug nuts when I put the new tires on. Today I may take the whole day and clean up the X and get it ready for storage.
  #110
Old 11-07-2010, 08:37 AM
CrzHelm's Avatar
CrzHelm CrzHelm is offline
CrzHelm is gaining momentum as a positive member of FTE.CrzHelm is gaining momentum as a positive member of FTE.
Well let just say Im not a happy camper. I just did the front half of my new procomp 6" lift kit and I'm very disgusted right now. What a total pos design. The new front leaves are 2" shorter than the original ones and now my axle is too far forward more than 2". And that combined with the increased height at the front axle the drive shaft is now way over extended. On top of that the new track bar drop down bracket dont line up with the track bar making my track bar 1" too short. Imo the hole is in the wrong place. Sorry i have to vent and think about what i need to say when I call Procomp. I'm on my out to do the rear. will report back later.
  #111
Old 11-07-2010, 09:02 AM
Snowseeker's Avatar
Are you sure the leaf springs aren't backwards?
  #112
Old 11-07-2010, 10:02 AM
twisstedex's Avatar
twisstedex twisstedex is offline
twisstedex is starting off with a positive reputation.
yes double check it.....as for today i hafta figure out y my offroad lights quit working and in stall my highlift jack on my roof rack,i finaly got my 37x20's to go with my 8inch super lift i just halfta find the time to do it .i just hope shes not to big..but i think shes gona look sick
  #113
Old 11-07-2010, 01:56 PM
Replaced my broken ignition lock cylinder and tried to fix the overhead display, but it still doesn't work Also noticed it has been dripping oil on the ground, so I guess I need to look into that, cuz I hate that.
  #114
Old 11-07-2010, 04:39 PM
Snowseeker's Avatar
Washed and clayed the X where it needed it, cleaned and wiped on conditioner for all the plastics and leather, vacuumed entire thing and floor mats. Just have to clean the glass, detail the small stuff, and maybe spray on the waste oil.
  #115
Old 11-07-2010, 05:08 PM
Flawless_X Flawless_X is offline
Flawless_X is starting off with a positive reputation.
what paint did you use to make your bumper gold?
  #116
Old 11-07-2010, 05:40 PM
Snowseeker's Avatar
I bought it like that. When I get paint I get it according to the factory paint code and use my sata gun to shoot it.
  #117
Old 11-07-2010, 08:01 PM
CrzHelm's Avatar
I triple checked that. the longer end of the spring is toward the front. also the longer side has a double military wrap around the bushing which will not fit in the shackle. it would be hard to f that up.
I really shouldve done the 4" kit. My front end is up 9.5 inch's from before. I didnt take in consideration that my original springs were worn and only 1" off the bump stop. I was probably 3" down from new then adding 6 more put me at just over 9". you can see the shock and sway bar links are slanted forward now and before they were straight up and down. at least I got the rear lift done today so its all done now. I got the track bar to line up but I had to start it up and turn the steering wheel to shift the axle over so i can get the bolt in. now on the highway my steering wheel is pointed at 9:00. I wonder what the guy at alignment shop is gonna say. I doubt 35" tires are even gonna clear the bumper. see what happens tomorrow.
  #118
Old 11-08-2010, 12:37 AM
Skip1970's Avatar
Skip1970 Skip1970 is offline
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
Changed my rear diff fluid and added new friction modifier to it also. and painted the rear cover also.
  #119
Old 11-08-2010, 12:39 AM
AlaskanEx's Avatar
AlaskanEx AlaskanEx is online now
AlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputation
drove it, washed it, filled it up lol
  #120
Old 11-08-2010, 06:14 AM
mark996's Avatar
mark996 mark996 is offline
mark996 is gaining momentum as a positive member of FTE.mark996 is gaining momentum as a positive member of FTE.
I'll be changing plugs and boots, air filter, fuel filter, oil filter, oil, cleaning up the interior, and possibly a few other minor things. This will consume probably an entire day in itself. Eventually, hopefully within the next few weeks I'll do the stealth mod to the wheels with some bed liner.
Replacing the rear speakers in a 2010 Regular Cab propellerhead Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 14 06-22-2016 06:34 PM
78/79 RestoMod Raleigh1 1978 - 1996 Big Bronco 682 03-18-2016 02:29 PM
MY '03 EXCURSION...WITH '08 FRONTEND. DaXman Excursion - King of SUVs 30 07-03-2015 06:38 PM
1984 F150, 302, C4 with a few minor problems eqppwqqep 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 47 07-08-2010 12:40 PM
Pic's from the Langham parade and show skidooman Manitoba / Saskatchewan Chapter 8 08-09-2007 03:59 AM
Tags
20x10, bouncing, excursion, f250, f350, ford, fuel, hydro, wpt943
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
