What did you do to the X today? - Page 51 - Ford Truck Enthusiasts Forums
  #751
Old 07-09-2011, 12:42 AM
robert_l_ross's Avatar
robert_l_ross robert_l_ross is offline
robert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputation
Started the install of my 650 dash as well. RiffRaff does a GREAT job - the paint is easily a 99% match. I only sent the trash hook (didn't find those back two screws until today), so for all I know it could have actually faded along the upper half. You can see an ever-so-slight difference between the cupholder and the panel, but the paint at the trash hook is dead on, so I'm guessing had I sent the cup holder too, they would have matched it dead on.
The switches are AWESOME...engraving came out great. Pigtails on the harnesses are a tad short, but not short enough to stress over. I'll have it back apart to put in the gauges (trans temp and oil temp) once I find gauges I like and once I find the best place to tap into the dash dimmer.
Does anyone know if those switches dim, or are they the non-dimming LED's?
  #752
Old 07-09-2011, 07:52 AM
extech extech is offline
extech is starting off with a positive reputation.
Installed Gibson exhaust on v10. Old system was rusting away.
  #753
Old 07-09-2011, 09:55 AM
Riffraff Performance's Avatar
Riffraff Performance Riffraff Performance is online now
PREMIUM SPONSOR
Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.
Send me your upholder and I will hit it as well
Get some Isspro EV2 gauges, they match great and a very good quality made right in Portland, OR.
The switches are done dimming but the aren't very bright with the engraving. For your gauges you will want to tap the dimming wire right behind your headlight switch, IIRC it is baby blue and pink tracer.
  #754
Old 07-09-2011, 11:13 AM
Quote:
Really? Yet another reason you guys rock! We have a display coming up for the fair...let me get it through that, then I'll send it to you.
I wondered when I had it apart if I could just piggyback on the dimmer switch itself. Maybe I will just have the switches illuminated with the ignition circuit and the gauges on the dimmer...the switches are far enough away from the windscreen they shouldn't hurt being at a "bright" setting all the time.
  #755
Old 07-09-2011, 02:23 PM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
-Hand washed the X today, degreased the motor with some Gunk Engine Brite Gel, and followed with the Gunk Engine Brite Shine.
-Filled her up today, cost $103 from a half way below half tank.
-Cleaned out the interior, still need to take some Lexol to the leather though.
  #756
Old 07-09-2011, 02:50 PM
vrinner's Avatar
vrinner vrinner is offline
vrinner is starting off with a positive reputation.
Got the Hellwig rear sway bar installed. From what I can tell so far it's helping. Certainly corners better. Cant believe people have these things for 100,000 miles and dont do this simple upgrade.
Plus...I love working on this truck because you can do so much without having to jack it up and use jack stands.
  #757
Old 07-09-2011, 09:50 PM
Goobzilla Goobzilla is offline
Goobzilla is starting off with a positive reputation.
I washed and vacuumed it after the road trip. It's green again!
  #758
Old 07-10-2011, 03:50 PM
cficare cficare is offline
cficare is gaining momentum as a positive member of FTE.cficare is gaining momentum as a positive member of FTE.
What did I do?
I updated the for-sale ad in the FTE classifieds section (link below).
http://www.ford-trucks.com/forums/10...ml#post9446299
2005 EB V10 4WD w/ 66,400 miles.
  #759
Old 07-10-2011, 09:49 PM
High Intentions's Avatar
High Intentions High Intentions is offline
Mod Specialist ;)
High Intentions has a superb reputationHigh Intentions has a superb reputationHigh Intentions has a superb reputationHigh Intentions has a superb reputationHigh Intentions has a superb reputationHigh Intentions has a superb reputationHigh Intentions has a superb reputationHigh Intentions has a superb reputationHigh Intentions has a superb reputationHigh Intentions has a superb reputationHigh Intentions has a superb reputation
Won 2nd place best ford at 4 wheel jamboree in Bloomsburg Pa. this weekend...
  #760
Old 07-10-2011, 10:52 PM
alabamabuddog alabamabuddog is offline
alabamabuddog is gaining momentum as a positive member of FTE.
Spent all day pulling down the AC compressor.
  #761
Old 07-11-2011, 05:20 AM
locknload223's Avatar
locknload223 locknload223 is offline
locknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud of
Quote:
Nice work!! Congrats .
  #762
Old 07-11-2011, 07:28 AM
fordboy67's Avatar
fordboy67 fordboy67 is offline
fordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant future
Very cool! Congrats!
  #763
Old 07-11-2011, 09:37 AM
slenser slenser is offline
slenser is gaining momentum as a positive member of FTE.
Swapped out the rear rotors. NO MORE SHIMMY!!!
  #764
Old 07-11-2011, 10:29 AM
Nosedive1 Nosedive1 is offline
Nosedive1 is starting off with a positive reputation.
Did the door seal mod on all four doors. WOW what a difference, no more door rattles. I should have done this a long time ago.
  #765
Old 07-11-2011, 11:21 AM
VR6Nutt's Avatar
VR6Nutt VR6Nutt is offline
VR6Nutt has a good reputation on FTE.VR6Nutt has a good reputation on FTE.
The X was hard to start Sunday morning. Thought the kids must of left lights on or something. So went with the family to Home Depot. Upon leaving, no start! Friend gave me a jump. Limped home. Weird thing is no accessories worked at all, except A/C. Got it home and tested voltages. Was 7V coming from alternator. Got a new one from Autozone and a new serp. belt why I was at it. In the process I realized the geniuses at Ford designed the top rad hose to go thru the belt! WTH? Drained some coolant, removed hose. Back together now, charging properly. But my damn ABS light is on now! Any ideas?
Replacing the rear speakers in a 2010 Regular Cab propellerhead Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 14 06-22-2016 06:34 PM
78/79 RestoMod Raleigh1 1978 - 1996 Big Bronco 682 03-18-2016 02:29 PM
MY '03 EXCURSION...WITH '08 FRONTEND. DaXman Excursion - King of SUVs 30 07-03-2015 06:38 PM
1984 F150, 302, C4 with a few minor problems eqppwqqep 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 47 07-08-2010 12:40 PM
Pic's from the Langham parade and show skidooman Manitoba / Saskatchewan Chapter 8 08-09-2007 03:59 AM
Tags
20x10, bouncing, excursion, f250, f350, ford, fuel, hydro, wpt943
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
