I would use a 5 gallon bucket to prop up as close to the bottom of the frame as possible. That would catch about 99% of the fuel and the only thing that go bathed was the one hand undoing the plug. Not to bad that way.
Thanks for the link! Just using a hex driver, a few extensions, a swivel and usually I can clear the member and 4wd housing. Light went out today, still gonna check it though.
I just don't get it with all these people not doing build threads.....
I had to get up off the floor. I fell out of my chair from laughing so hard. I realize that was the point, but from all people Tim. That was hilarious. Thanks.
Yeah I know.....
That was the irony!
I have all my pics ready at least! Need to dig out my notes to match up with the pics..
Installed 2010 F350 crew cab front seats and console:
Had to move the heated seats control from being on the dash to on the seat:
Interesting, I may be interested in doing this at some point in the future, since the leather on the seat back of my 2000 X's driver seat has now started to separate around the 'Limited' (or whatever) stitching that is high on the seat back.
I was planning on maybe getting my old seats recovered, but if the 2010 seats are really that much more comfortable, I may reconsider. Are they really that much more comfortable, and if so, in what way?
Also, are the seats (except for the relocation of the heater controls) a direct plug in (i.e. bracketing, seat rails & electrical connectors etc.)? Is it necessary to use the new center console with the new seats, or just something that you opted to do to update the interior? And lastly, where did you get the updated seats from, and how much did they cost?
The leather is softer as is the foam. The new seats do not have arm rests built in so u need the console or a center seat. I removed the plastic part of the harnus on my old seat and just rearanged the wires to the correct order. They bolted right in. I got them from eBay cost 600 shipped.
See... write-up! This forum is built on other's experience. Share the wealth... of knowledge.
Got the dreaded water in fuel light today. Gonna pull the plug on the frame mounted filter and see if it has a bunch of junk on it. Just changed both filters about 1000 miles ago. I hate doing that frame mounted filter. Pulling the little plug is worse. Can you say diesel bath?
Oh Tim, you're bringing back memories of the shower of antifreeze I got when I pulled the rear coolant lines to the rear A/C and heat. Turns out all the coolant wasn't drained after all...
Interesting, did the eBay ad say how many miles were on the seats? My dad's F-450 seats are much firmer than my '02, but comparable to the '05. I guess the '02 just has more miles/use to soften up the foam.
The arm rest issue is a big deal for me personally. For where I put the seat (higher up), the console is much too low and away from me. Since I don't get to drive it much, when I do, I usually take a jacket or blanket and bunch it up between me and the console to simulate an arm rest. On the other hand, for whatever reason my dad likes the seat as far back and as low as he can, so he's content with where the console is at then.
Hmm, I have a custom floor console, that sits on the transmission tunnel between the regular console between the seats & the dash, so necessitating a swap to the later model console may make this a no go for me, unless the shape of the bottom of the later model console is the same or very similar to that of the original.
However, as others may be interested:
- did the $600 include the console, or did you have to source that separately?
- how close a match is the later model tan leather to the rest of the earlier model tan leather interior?
- so I guess the later model console (and its interior) is wider, and one is intended to use the console as an armrest?
